Author Topic: Wiring 12v marquee light.  (Read 2133 times)
KapnKerfuffle
  • Last login:November 23, 2016, 11:48:14 pm
« on: March 03, 2010, 01:41:48 pm »
I have a cold-cathode marquee light from Ultimarc.  It has 2 wire leads that are supposed to connect up to a 12v power supply.  What is the best way to connect these to a 12v molex connection in the computer?
Think the Unthinkable, Know the Unknowable,
Screw the Inscrutable and Eff the Ineffable.
Ed_McCarron
Re: Wiring 12v marquee light.
« Reply #1 on: March 03, 2010, 02:02:25 pm »
Scavenge the mating 12v plug from a peripheral.  Yellow = +12v, Black = Gnd.
« Reply #2 on: March 03, 2010, 02:02:53 pm »
hack a Y molex splitter  yellow is +12v, black is ground, red is +5
MonMotha
« Reply #3 on: March 03, 2010, 02:36:07 pm »
If you've got a Fry's nearby, they probably have the mating connector.  A bag of like 5 or 10 housings was a few bucks, and a bag of 100 pins was I think $10.
If you don't, slice apart some PC thing you don't care about.  Dead cooling fans work great for this.  As others have said, Yellow = 12V, Black = GND.  The cooling fans sometimes hook a red wire up to the 12V side, so don't get confused if you hack one of those apart (and you probably don't want to use that thin little wire, anyway).
« Reply #4 on: March 03, 2010, 04:50:45 pm »
This video may help.
D
KapnKerfuffle
« Reply #5 on: March 04, 2010, 12:04:44 am »
Oh too late.  Thanks for the vid though.  I already did my butt splice.  It turned out o.k.  I didn't have a nice heat gun to heat shrink it, but the lighter did a passable job.  It took a while for the cold-cathode to "warm up" (pun... yeah intended, waiting all night to drop that one).  But it looks great.
