Author Topic: Slingshot Machine Gun  (Read 4631 times)
Neverending Project
    • Arcade Fixer
« on: March 02, 2010, 04:44:15 pm »
One of my slingshot kicker solonoids fires rapidly for about 5 seconds after the ball hits the bumper to trigger it. I am guessing it is a problem where the rubber is triggering the switch when the kicker returns to its resting position. But the switches seem to have a decently sized gap when the rubber is at rest.
What might this be? Is there a capacitor on the switch leads to slow the response that might be bad? It is a new rubber ring - could it be too loose?
Jeff AMN
    • Gamer Theory
Re: Slingshot Machine Gun
« Reply #1 on: March 02, 2010, 06:13:51 pm »
Sounds like your rubber may actually be too tight.  Just gap the switches a little bit more and you'll be good to go.
I had this same issue with my Taxi after a shop job and this was the cure.
Neverending Project
    • Arcade Fixer
« Reply #2 on: March 02, 2010, 11:00:26 pm »
Thanks, I'll give it a try. What about a flipper coil that sticks in the energized position until you hit the flipper button a few times? I'm fairly sure it's not mechanically stuck, as there is no friction when I move it to the extremes. And the eos switch is opening when the pawl pushes it.
pinballwizard79
« Reply #3 on: March 24, 2010, 12:50:29 am »
I totally thought this would be a sling shot machine gun video on youtube, started to get pissed when I figured out it was pinball related & then realized I was in the pinball section
FML
shardian
« Reply #4 on: March 25, 2010, 07:01:21 pm »
A friend had the exact same issue on his MotorDome pin. I fixed it by adjusting the switch gap and cleaning the contacts.
Neverending Project
    • Arcade Fixer
« Reply #5 on: March 29, 2010, 06:02:31 pm »
Adjusting the gap on the switches seems to have done the trick. The flippers haven't stuck since, so I have yet to dig deeper into that issue. Thanks!
shardian
« Reply #6 on: March 29, 2010, 11:44:17 pm »
Cleaning the contacts accomplished nothing.  The problem was too much contact, not lack of contact.   ;)
Glad to hear it's working out for you, Neverending.
Probably not, but if you are already there one more simple maintenance step is just good practice. Yeah, how dare I clean contacts. That was soooooo stupid... ::)
