Author Topic: Need help creating overlay for control panel  (Read 1938 times)
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« on: March 02, 2010, 01:28:32 am »
Hi Everyone So this is the overlay I'm thinking of using for this cp, I'm trying to make an overlay for it but I am not sure how to begin the process. Jack said I could use illustrator to open the CAD  file and save it as a photoshop file then fix it up. Here's the CAD file http://www.megaupload.com/?d=SKM1WHPT Can someone turn it into a photoshop file for me? I'd really appreciate it.
My cp will have no flight stick and  no track ball buttons (will use the 4 way joystick ones for that). And the admin button layout (and the reason you see those button surround on top) are as follows
players 1 coin and start on left
player 2 coin and start on right
exit, pause, favs, and genre button in the middle.  The genre button is in case I decide to use hyperspin.
The  p1 and p2 button layout will be as follows (thanks t3 design for sharing)
Opinions? I might have to move the invader a little bit so it doesn't get clipped by the buttons though
I also gotta thank Delusional for sharing the adobe photoshop file! Thanks!
« Last Edit: March 03, 2010, 12:40:45 am by shateredsoul »
shateredsoul
Re: New Control Panel Overlay, What do you think?
« Reply #1 on: March 02, 2010, 01:34:13 am »
Here are the dimensions
# Control panel is 35" wide and 18" deep.
#  Panel base is 5.75" tall facing the video source and slopes down to 5" facing the player.
Is there a better way to design this to check if it will fit these dimensions? The image of the overlay I have looks thinner and longer than the cp.
ubiquityman
  • Last login:May 06, 2016, 10:57:58 pm
« Reply #2 on: March 02, 2010, 08:22:05 pm »
If you label the CP, I'd be better able to understand the layout.
I'd move the thumb button up a bit so that it's compatible with defender.
shateredsoul
« Reply #3 on: March 03, 2010, 12:39:19 am »
What do you mean by moving the "thumb" up?
Here's a labeled CP, this is pretty much exactly what I want, I'm just gong to ask him to move the p1 coin and start buttons closer to the left.
« Last Edit: March 03, 2010, 12:42:34 am by shateredsoul »
