Author Topic: LEDBlinky and Mamewah issue on startup  (Read 2263 times)
mccoy178
  • Trade Count: (+9)
  • Last login:August 20, 2026, 01:21:00 pm
  • Go Bucks!
« on: March 01, 2010, 10:38:50 pm »
Hello,
Upon starting Mamewah, with Ledblinky selected as a launching app, I get a solid black screen.  I have to scroll down to the bottom, right click on the ledblinky icon over on the right and exit it.  Upon exiting of it, Mamewah works like normal.  Any suggestions?  Here is my latest Mamewah log:
3/1/2010 10:32:25 PM MAMEWAH launched
3/1/2010 10:32:25 PM Cursor scheme: Windows Default, Arrow: C:\WINDOWS\Cursors\arrow_i.cur, Wait: (None), AppStarting: (None)
3/1/2010 10:32:25 PM Desktop colour: 9981440
3/1/2010 10:32:25 PM Wallpaper filename:
3/1/2010 10:32:25 PM Display mode: 800x600 @ 60Hz, 32 bit colour
3/1/2010 10:32:25 PM Decimal symbol: '.'
3/1/2010 10:32:25 PM Games list read: mame-2.lst
3/1/2010 10:32:25 PM Current drive/directory selected: C:\LED Blinky\LEDBlinky
3/1/2010 10:32:25 PM Commandline run: C:\LED Blinky\LEDBlinky\LEDBlinky.exe {flags=210}
3/1/2010 10:32:44 PM Application quit: C:\LED Blinky\LEDBlinky\LEDBlinky.exe
3/1/2010 10:32:45 PM Mode 0 x 0 @ 0Hz, 0bit colour selected after 2 attempt(s) at 1/2 second intervals.
3/1/2010 10:32:45 PM Mode 800 x 600 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
3/1/2010 10:32:45 PM Layout selected: C:\Mamewah1.62\config\mame\jcrouse\layout.lay
3/1/2010 10:32:46 PM No. joystick devices attached: 0
3/1/2010 10:32:46 PM Ctrlr file selected: C:\Mamewah1.62\config\mamewah.cfg
3/1/2010 10:32:46 PM Keyboard enabled
3/1/2010 10:32:46 PM Mouse enabled
3/1/2010 10:32:53 PM Current drive/directory selected: C:\Mamewah1.62
3/1/2010 10:32:53 PM Commandline run: C:\Mamewah1.62\exit.lcd {flags=210}
3/1/2010 10:32:53 PM Mode 800 x 600 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
3/1/2010 10:32:53 PM Mode 800 x 600 @ 60Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
3/1/2010 10:32:54 PM MAMEWAH quit
arzoo
  • Last login:July 05, 2026, 11:11:48 pm
  • Robots WILL kill you.
    • LEDBlinky
Re: LEDBlinky and Mamewah issue on startup
« Reply #1 on: March 03, 2010, 08:24:45 am »
The LEDBlinky support site has some info on how to configure Mamewah with blinky. I'm guessing you need the {nowait} flag added to the launch command.
http://www.dndw.com/arcadeaddiction/LEDBlinky_Support.htm#MamewahConfig
If that doesn't help, turn on the debug and verbose options and email me the debug.zip file.
http://www.dndw.com/arcadeaddiction/LEDBlinky_Support.htm#ItsNotWorking
« Last Edit: March 03, 2010, 08:26:23 am by arzoo »
Robots will kill you.
Arcade Addiction
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #2 on: March 04, 2010, 09:02:26 pm »
That was it!  I tried using the search feature on here and I just couldn't find the correct wording I guess.  Thanks again!  I have not had any success with it running inside of Mamewah itself.  It is on, but it only lightly flashes when a sound is made.  There is no randomization of the lights or such.
arzoo
    • LEDBlinky
« Reply #3 on: March 05, 2010, 08:45:41 am »
Most likely a configuration issue. If you can't figure it out, send me the debug.zip and I'll take a look.
Arcade Addiction
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #4 on: March 05, 2010, 01:30:19 pm »
Thanks again!  Will do.  Now I'm going to get this installed on the jukebox. :cheers:
reko19
  • Last login:May 19, 2026, 04:14:02 pm
« Reply #5 on: March 09, 2010, 10:38:39 am »
let me know if you are still having issues, I have it working with mamewah and could send you my ini files.  The only issue so far is for PC games, other than that works 100%.
