Author Topic: Cool little program.....  (Read 3387 times)
P-Funk
  • Last login:August 30, 2003, 01:50:44 pm
  • Mmmmmm, Beer.......
« on: July 26, 2003, 05:42:06 pm »
Hey all,
I recently found myself in a position of having to unzip several thousand roms files.  I found a cool little program called 'Unzip Them All'.  It worked great for me.  You can grab it here.
http://www.herve-thouzard.com/unzipus.phtml
Word of caution though:  It defaults to creating a sub directory for each unzipped file.  Doh!  So change that setting first.
AlanS17
    • AlanS17
ROM zips vs. individual folders
« Reply #1 on: July 26, 2003, 05:54:17 pm »
How beneficial would it be to have every MAME rom open in its own folder rather than using the ZIPs? I wonder i it could substantially increase loading times...
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Cool little program.....
« Reply #2 on: July 28, 2003, 03:13:12 am »
And if you unzip the ROMs, the files need to be in their own folders with the same name as the zip file, anyway.
I say keep them zipped, though.  (Depending on the CPU speed vs the harddrive speed) Many modern computers can load and unzip a zip file faster than loading the same files (as in the zip file) unzipped on the same harddrive.  Plus the disk space you save, CMPro, and copying/backing up, why unzip?  *shrug*
Robin
Knowledge is Power
P-Funk
« Reply #3 on: July 28, 2003, 11:34:27 am »
I used it for my Atari 2600 and NES roms.  Because I was having trouble getting Z26 and Nester to read zip files.  Once unzipped, everything worked great.
eightbit
  • My cab is never done...
« Reply #4 on: July 31, 2003, 08:55:24 am »
Oh the world of GUI interfaces. DOS pkunzip wasone of the origanel compression tools and it could handle an entire directory of zips to be unzipped at one time...
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #5 on: August 08, 2003, 08:27:34 pm »
winRAR allows you to unzip multiple zip files. I use this program for everything compression related. Much better than winZIP
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
« Reply #6 on: August 08, 2003, 10:52:36 pm »
CitznFish is right.  Plus, WinRAR gives you the ability to unzip multiple archies into their own directory with the same name as the zip filename anyway.
Best archiving/unarchiving utility I've ever used.  By far.
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
_Iz-
  • Last login:Yesterday at 10:41:02 am
  • Time to coin up!
« Reply #7 on: August 14, 2003, 03:12:09 pm »
Winzip will unzip multiple files at once.
You select them all in windows explorer, right click somewhere in the highlighted area and then in the pop-up menu choose winzip -> extract to (here)...
IceCold
  • Last login:March 22, 2010, 05:11:22 pm
    • My MAME cabinet webpage
« Reply #8 on: August 15, 2003, 09:12:19 pm »
winace does the same thing too.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #9 on: August 16, 2003, 12:53:12 am »
why?
