Author Topic: seeking control panel feedback  (Read 2030 times)
specfire
  • Last login:March 21, 2026, 04:58:37 pm
  • Shhh...
« on: February 23, 2010, 11:37:43 pm »
Standard layout.  I put 2 rows of 4 buttons across the top for 2 x TT2 spinners, player 1 and 2 coin and start, and 2 admin buttons.
Do I have enough space between the trackball and the other controls?
BTW, the horizontal dotted line is where the leading edge bend will be (metal control panel.)
Thanks for all your comments.
Read to your kids, you'll all be better for it.
specfire
  • Shhh...
Re: seeking control panel feedback
« Reply #1 on: February 24, 2010, 10:30:51 pm »
My main question:
What is the minimum distance for a 3" trackball from the player 2 joystick in order to prevent most hand strikes?
dullivan
  • Last login:March 25, 2010, 06:57:15 pm
« Reply #2 on: February 25, 2010, 06:53:36 pm »
Good question. I've been concerned with this myself, as I'm getting geared up to start my first project. Anyone around that can offer some guidance?
Also, what did you use to use to generate your layout graphic you've got there?
specfire
  • Shhh...
« Reply #3 on: February 25, 2010, 08:04:07 pm »
I can't take credit for creating that, my buddy used SolidWorks.  He has access to a CNC machine to cut it into a metal panel.  We are planning on using aluminum instead of steel and then hard anodizing it.
I was thinking of 12 gauge, can anyone let me know what the minimum gauge of an aluminum control panel should be?  Perhaps Franco?
Thanks, spec
« Reply #4 on: February 25, 2010, 09:44:28 pm »
Did a quick measure on my X-arcade.
It is 5-3/8" from the center of the ball to the center of the joystick shaft.
It's about 3-1/4" from the edge of the trackball cutout to the edge of the joystick ball.
« Last Edit: February 25, 2010, 09:46:03 pm by BadMouth »
