Author Topic: MAMEWAH won't run!  (Read 1825 times)
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
MAMEWAH won't run!
« on: July 26, 2003, 07:39:45 am »
I'm using Windows 98, Pentium 1 (100MHz), 64MB RAM, 8GB HDD, and MAMEWAH crashes every time I open it.
Before I had the skins unzipped, it ran without crashing (I just couldn't do anything, because there was no skin!). When I unzipped the skins into the correct folder, MAMEWAH now crashes. What's going on?
Re:MAMEWAH won't run!
« Reply #1 on: July 27, 2003, 10:26:33 am »
What does it do - how does it 'crash'?
Are you sure you unzipped the layout stuff to the correct folder?
EndTwist
  • Arg.
« Reply #2 on: July 27, 2003, 10:53:36 am »
1. I get the "This application has blah..blah..blah", you know, the deadly error where the message box comes up and gives you the 2 buttons, "Close" and "details >>"
2. Yes, I'm not an idiot.
BTW - I know much more about computers than you probably think, but I thought I'd ask the creator of the program.
« Reply #3 on: July 27, 2003, 11:10:46 am »
I wasn't assuming you knew nothing, but depending on the crash it may have been related to the layout stuff also based on the info you gave.  That was the only thing I could think of.
Are you using Win 98SE?  Maybe it has problems with versions previous to SE, I cannot say 100% as I have not tried it.
EndTwist
  • Arg.
« Reply #4 on: July 27, 2003, 11:13:08 am »
I don't belive it is SE. I am sure everything is set up correctly, so maybe its a compatability problem between [that] VB6 program and Win98?
« Reply #5 on: July 27, 2003, 11:26:02 am »
Possibly, as I say I have not (cannot) try it with a Win98 version previous to SE.
That said, I have not heard any other complaints - but perhaps every Win98 user running MAMEWAH uses SE (?)
Sorry, I don't know what else to suggest :(
