Author Topic: Metal Control Panel Options  (Read 1490 times)
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« on: February 17, 2010, 12:31:12 pm »
I'm thinking about making a metal control panel for an upcoming project.  I'm not a huge fan of bolt heads on my cp.  I read some stuff about stud welding and that looks promising if I can find someone in town to do it.  What other options do I have?
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
Necro
  • Last login:December 31, 2025, 03:36:17 pm
Re: Metal Control Panel Options
« Reply #1 on: February 17, 2010, 01:54:41 pm »
I believe that is about it.  There are a few other 'oddball' options though involving your overlay and plastic or some other material.
  • Recess a space into your plexi overlay so the bolt is in that and not 'sticking up' on the CP.  Still visible, but you won't touch it.
  • As above, but put your CP graphic ON the plexi/hardboard/whatever overlay material you use first.  If you want plexi on this, it might get a bit thick.
  • Construction glue or weld support structures (wood or metal, respectively)  to the bottom of the CP.  Use these to hold everything in place.
I'm not totally familiar with it, but I think 3 might be the best option if you can 'bottom mount' the controls and JB Weld would be strong enough for this. You could do a very high surface area mount that covered nearly the length of the CP, then drill through that along with the top CP.
