Author Topic: Wiring LEDs with Minipac and harness?  (Read 1638 times)
korbitz
  • Last login:June 30, 2017, 01:09:54 pm
« on: February 15, 2010, 03:12:44 pm »
Okay read some threads about people adding LEDs to their minipac but cant find any posts about how it is done.
Currently i am using the minipac with the harness, i also have a cpl LEDs kicking about and would like to make a use out of them.
Any help would be appreciated
p.s. my wiring skills aren't the greatest so non-layman terms would be appreciated
BobA
  • What Me Worry?
Re: Wiring LEDs with Minipac and harness?
« Reply #1 on: February 15, 2010, 04:35:04 pm »
I think it depends on which minipac you have.  The early ones had a header that was like the one on the ipac for keyboard leds.  Looking at the new wiring diagram I do not see this header on the newer minipacs.
korbitz
« Reply #2 on: February 15, 2010, 05:04:02 pm »
The version i have isn't the same as the one displayed on the website, it has a row of 9 pins in 2's going vertically as opposed to horizontally for the harness.
So are these pins used as keyboard LEDs? with the diagram i got with the board, there was nothing on the diagram about these pins.
BobA
  • What Me Worry?
« Reply #3 on: February 15, 2010, 05:36:43 pm »
I think the old minipac header was the same as the one on the ipac.
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
« Reply #4 on: February 15, 2010, 05:48:04 pm »
If you want to run LEDs from the minipac, just use the 5V with a resistor. There are 3 x 5V connections on the new one but it doesn't have connections for keyboard LEDs.
I'm not sure how many you can get away with but you can certainly run a couple off it. I use one on the trackball.
BobA
  • What Me Worry?
« Reply #5 on: February 15, 2010, 06:37:55 pm »
I think he is trying to get the keyboard harness working not just power to the LEDs
