Author Topic: can you use a sanwa JLW mounting plate with a JLF stick?  (Read 2054 times)
gse123
  • Last login:April 10, 2010, 11:25:19 am
« on: February 14, 2010, 07:19:54 am »
I currently have sanwa JLW sticks on my cab, mounted by the far corner holes. I want to change to JLF's, but due to the completely different sized mounitng plate it puts me in a pickle, as the bolt threads on my steel CP are welded in place, and I'm not in the position at the moment to start trying to mod the CP itself.
Just wondering if the screws that fix the mounting plate are in the same positions on the JLW and JLF, so I can get round it that way.
Jack Burton
Re: can you use a sanwa JLW mounting plate with a JLF stick?
« Reply #1 on: February 14, 2010, 01:57:22 pm »
They are not compatible.
I don't think it would be difficult to manufacture custom mounting plates though.  There was a guy on arcadeotaku.com who was making some a while back.  You might want to check there.
