October 09, 2026, 06:19:23 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Main
Woodworking
Router Bits types: 1/4" vs. 1/2" shank?
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Router Bits types: 1/4" vs. 1/2" shank? (Read 8530 times)
r32
Trade Count:
0
Full Member
Offline
Last login:December 18, 2011, 05:44:28 pm
on:
February 05, 2010, 03:50:16 pm »
Some facts:
1. I'm a total newbie to woodworking, but am getting hooked, fast!
2. My first use of a router will be my new arcade cabinet.
3. I own the DeWalt DW616PK Router Kit (comes w/ 1/4" and 1/2" collet).
4. I also own the DeWalt D26670 Router. (1/4" collet diameter)
For my arcade cabinet:
1. I'm ordering 3/4" T-Molding from
www.T-Molding.com
2. The 3/4" T-Molding I'm ordering has a 3/32 Spine that is 19/64 in Depth.
3. According to the
www.t-molding.com
website, I need a 3-wing router bit with 1/16" slot width.
4. I'm looking to purchase my router bits from here:
http://www.mlcswoodworking.com
Questions on Router Bits:
1. Since I have 1/4" and 1/2" collet on my primary Router, should I go with one size over the other?
2. For creating the t-molding slot, is this the correct router bit I should be ordering: #5341 (1/4" collet) or #7641 (1/2" collet)?
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html
3. For trimming black laminate I will be using on sides of cabinet, what router bit do I need?
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/katana_bits4.htm
4. Will any other router bits be helpful in building my arcade cabinet?
Reference Images:
3/4" T-Molding from
www.t-molding.com
Slot Cutter Router Bit from
Laminate Trimming Bit from
Last Edit: February 05, 2010, 05:03:43 pm by r32
Logged
Trade Count:
+1
Full Member
Offline
Last login:
Yesterday
at 04:08:02 pm
Re: Router Bits types: 1/4" vs. 1/2" shank?
Reply #1 on:
February 05, 2010, 04:55:40 pm »
That looks like the correct slot cutter. Do not buy a laminate cutting bit - buy a pattern or flush cutting bit - they do the same thing and are MUCH more versatile due to the longer blade. You can find them right below the laminate trimming bit you linked to - make sure the cutter height is at least 1" - I'd go with #18808 if it is your first one.
Note the bearing is on the top so you'd have to flip the piece you laminated upside down to make the cut. Or you could get a similar bit with the bearing on the bottom - I'd still make sure it has a 1" cutting height though. Look
HERE
Last Edit: February 05, 2010, 04:58:52 pm by javeryh
Logged
Bella's Arcade
DK+
Jack Attack!
Woodgrain Cabaret
Twin Tullys
r32
Trade Count:
0
Full Member
Offline
Reply #2 on:
February 05, 2010, 05:10:17 pm »
^Great! Thank you for the feedback and saving me some dollars on something not as useful.
So I will look at buying the #18808 you pointed out: (1" cut height w/ 1/2" shank)
Found here:
Or perhaps this cheaper one: #8807 (1" cut height w/ 1/2" shank)
Found here:
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_flush.html
Any advice on my question regarding 1/4" vs. 1/2" shank?
Is the term 'shank' referring to same thing as 'collet' ?
Ahhh after studying those router bit pics, I just got the reason for bearing being on top vs. bottom and how that affects the way I will cut the board. They also have a router bit with a top and bottom bearing. Any advantage there, and if you bought this router bit for this job, would you prefer a top or bottom or both bearing router bit?
Reference Image:
Pattern/Flush Trim Router Bit from
Pattern/Flush Trim Router Bit TOP BEARING from
Last Edit: February 05, 2010, 05:49:45 pm by r32
Logged
fixedpigs
Trade Count:
0
Full Member
Offline
Last login:August 19, 2025, 01:29:35 pm
warning: drew can't handle my avatar...
Reply #3 on:
February 05, 2010, 08:15:22 pm »
1/2" shank is generally always better than 1/4"...the bit will run smoother and have less vibration...
really...the only reason i can think of to ever get a 1/4" shanked bit...would be if your router could only accommodate 1/4"...
(edit)
since you have that laminate trim router...i'd suggest getting the laminate trim bit for it...you have a specific tool...you may as well have it perform its task the best that it could...in which case it'd use the 1/4" shank...
but you should get all other router bits in 1/2" shank for your actual router...
Last Edit: February 05, 2010, 08:29:18 pm by fixedpigs
Logged
r32
Trade Count:
0
Full Member
Offline
Reply #4 on:
February 05, 2010, 08:59:38 pm »
Thanks fixedpigs for the feedback.
True, I have that laminate-specific router. In fact, I just picked it for $60 as a refurb from
www.Rockler.com
which is fantastic price, because usually they are $110+.
Ok, so I'll just go ahead and get a laminate specific cutter then, in 1/4" shank just for that tool, then pick up all other router bits in 1/2" shanks for my bigger router. Really excited to get this project going, but I want to plan everything out very well and make sure I have all the tools and materials and plans to do this right the first time.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Woodworking
