Author Topic: Can someone explain control hack to me?  (Read 1713 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: July 24, 2003, 10:08:58 pm »
Ok so I have dreamcast I want it in my cab with my pc. How do I switch between the two? How do I hook the dreamcast up to my arcade controls? I know I have to hack a controler. Do I have to disconnect everything from my computer and then connect all the wires to dreamcast?
Please Help
Confused... err. Shieldwolf
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
Re:Can someone explain control hack to me?
« Reply #1 on: July 24, 2003, 10:49:24 pm »
This should answer some Q's, I prefer the diode method:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=9823;start=msg73333#msg73333
that thread directs you to the original thread so read em both. Good luck happy hacking
Derek
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #2 on: July 24, 2003, 11:34:20 pm »
You might also want to look at the Game Consoles section right here on BYOAC.
http://www.arcadecontrols.com/arcade_consoles.shtml
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #3 on: July 25, 2003, 07:59:21 am »
I can attest the diode method works - I have been re-wiring everything to accomodate the DC and there are no side effects whatsoever because of the diodes :)
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
« Reply #4 on: July 25, 2003, 09:38:09 am »
would you need to bother grounding the DC pad to every button, or could it share the same ground ipac input?
Frostillicus
  • Arcade Artist
« Reply #5 on: July 25, 2003, 09:40:16 am »
It can share the same ground as the ipac.  Don't use diodes with the grounds.
