Author Topic: Buying External HD  (Read 1130 times)
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
Buying External HD
« on: May 25, 2009, 03:59:27 pm »
Ok i need help i know there are some companies i should watch out when buying a hard drive ant recommendations
Grasshopper
Re: Buying External HD
« Reply #1 on: May 26, 2009, 01:38:08 pm »
Well personally I'd buy the drive and the enclosure separately. It will cost about the same as an all in one unit and you'll get your choice of capacity and drive brand. It will probably also be easier to upgrade the disk later.
Also, for maximum flexibility I'd suggest buying a combined USB2/e-sata enclosure. You can't go wrong with that combination and they're only slightly more expensive than a USB only enclosure.  USB gives you the widest compatibility because almost all PCs have USB ports these days. And for those PCs that have an e-sata port, you'll be able to achieve the same transfer speed as an internal drive.
myntik1
  • Last login:April 26, 2021, 12:03:28 pm
  • I'm part Jerry Lee and part Jerry Lee Lewis
« Reply #2 on: May 26, 2009, 01:45:06 pm »
this is from personal experience and not based on an independent taste test - buy in pairs, so you can back-up your info and the bigger drives IMHO are more prone to failure.
full-time sucker for part-time pay
