Author Topic: Wiring up a control panel advice please  (Read 2101 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: February 24, 2009, 01:34:15 pm »
Hi guys,
Im about to attempt to wire up my arcade control panel and have purchased a wiring kit from Ultimarc and was wondering if you guys could give me some tips on making it all look clean and getting it right. I have no real experience doing this and will be wiring up 3 admin buttons, 2 joysticks, 12 leaf switches and 3 pinball buttons on side of cab into an Ipac2.
« Last Edit: February 24, 2009, 01:40:39 pm by Marky_1979 »
  • Last login:Yesterday at 05:46:43 pm
Re: Wiring up a control panel advice please
« Reply #1 on: February 24, 2009, 03:23:07 pm »
Daisy chain the grounds together to GND on the iPac and run wires to the individual nodes on the iPac from the NO prong on the switch.  I'm not sure what other advice I can give you... If you want to keep it neat, invest in some ties and the little sticky things that the ties run through, plot a course for the wires generally and then tie everything together...
Encryptor
  • Trade Count: (+34)
« Reply #2 on: February 24, 2009, 03:51:47 pm »
Check out mountains wiring on his control panel in this thread.
http://forum.arcadecontrols.com/index.php?topic=63629.msg673766#msg673766
He tells you where to get the stuff to do it in this thread.
http://forum.arcadecontrols.com/index.php?topic=63629.msg674587#msg674587
Encryptor
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
« Reply #3 on: February 25, 2009, 09:18:54 pm »
dont look at mountains hes a miracle wireer hes like magic and dont try something as neat as him its really hard
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #4 on: February 25, 2009, 11:35:57 pm »
Very helpful advice (¬_¬)
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
ivwshane
    • My first mame cab! (WIP)
« Reply #5 on: February 26, 2009, 01:54:16 am »
I'd suggest looking at the various projects on this site. Everyone wires their cp differently so there should be plenty of ideas to pull from.
fiscap
  • Last login:November 24, 2024, 03:30:36 pm
  • I dare ye enter... the dungeons of daggorath!!!
    • BYOAC blog
« Reply #6 on: February 27, 2009, 05:15:48 pm »
There are many examples on the forums to explore. While I do agree that Mountain does an exceptional job at wiring, it would be very difficult for a novice to replicate - he did say he has 10+ years experience. I also wouldn't suggest the use of lacing cord since it is very difficult to change any wiring once it's been laced. That being said, it is possible for even a novice to obtain very good results keeping one rule of thumb in mind - take your time.
Some tips I would recommend are to use nylon wire ties and wire tie anchors (look like little 1" squares with holes to run the ties through). These will allow you to group wires running along similar paths together and to anchor them to your control panel. Both of these items are available at either Lowes or HD real cheap. The other recommendation I would make is to place your encoder at the central point of your controls and to run the wires from all the buttons and controllers to this point - tidying up the cables as you work your way back to the central point. Don't connect the wires to the encoder until you have the wires connected to the controllers and buttons, as well as the wires run down their respective paths to the encoder. This will allow you to take up all the slack, eliminating the need to conceal bunched up wires. During this process it would be best to only use one or two cable ties to secure the wires, allowing you the ability to easily identify each wire running to the encoder and make changes if necessary. Once you have confirmed all connections to the encoder to be correct, you can go back and add more cable ties to neaten up the job.
And by all means, follow javeryh’s advice and daisy chain the grounds – this will eliminate almost half the bulk of the wiring job.
Here is a sample of one of my control panel's from a couple of year's ago. I used terminal barrier strips for daisy chaining my grounds - more costly and time consuming, but equally as effective.
http://forum.arcadecontrols.com/index.php?topic=52759.msg590901#msg590901
Marky_1979
    • Personal Webspace
« Reply #7 on: February 28, 2009, 12:18:44 pm »
Thanks for all your advice guys I will take my time and make sure its the best I can make it
IreM72
  • Last login:March 28, 2009, 11:42:42 am
« Reply #8 on: March 17, 2009, 05:03:38 am »
Hi
I want to order the ultimarc wiring kit, but can't find it to order on the ultimarc website. Can anyone help?
Sir Headless VII
  • Last login:April 30, 2017, 02:04:52 pm
« Reply #9 on: March 17, 2009, 11:19:31 am »
IreM72
« Reply #10 on: March 19, 2009, 09:08:07 am »
