Author Topic: Visual/Video Pinball nudge panel?  (Read 3025 times)
Spinach
  • Last login:June 14, 2009, 10:55:38 am
« on: February 20, 2009, 10:34:16 am »
So I wasn't even that interested in pinball until I started reading all of these threads  :banghead:
Has anyone ever hooked up a thin panel in the front of their cab and placed the nudge buttons under them?  I'm thinking spacing with springs, so you could give your cab a little hip action and it would press the nudge button.  Maybe use a spacer in the middle to distinguish between left/right?
Sorry if this has been done before, didn't see it in my search.
Also, is this the right forum for this?  Please move if not.
Thanks,
Spinach
thatitalian
  • The Revolution Is Coming...
Re: Visual/Video Pinball nudge panel?
« Reply #1 on: February 20, 2009, 11:57:29 am »
I haven't heard of that, but mountain put a car alarm senor (so if the car gets nudged or moved the alarm sounds) so that when someone nudges the control panel the nudge feature activates.
Read more here
Quite a neat trick! ;)
« Last Edit: February 20, 2009, 12:24:54 pm by thatitalian »
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #2 on: February 20, 2009, 12:47:45 pm »
Pretty cool it can be done, but I don't fancy the idea of banging my machine and definitely not letting any of my mates do it!
« Reply #3 on: February 20, 2009, 12:59:35 pm »
That's pretty click to use a car alarm shock sensor.
I'm working toward doing the same thing but using a wiimote (the accelerometer is pretty sensitive in those things) or using a USB accelerometer for robotics to simulate the nudge buttons. That way, the sensitivity is completely programmable (so you don't have to wail on the cab to get it to nudge.
Still, TurnerCades has a point. Don't want to encourage bashing cabs:)
Maybe I just won't tell anyone else about it ;)
Kevin Mullins
    • Me on Myspace
« Reply #4 on: February 20, 2009, 01:58:35 pm »
You could use something simple like a slam switch commonly found on coin doors.
The sensitivity can be adjusted a bit by tweaking the leafs.
« Reply #5 on: February 20, 2009, 03:21:00 pm »
I wanted to do something more direct like that originally, but every mock up I tried, I ended up getting false positives in one direction or another (ie trying to trigger just a nudge left would often inadvertently trigger both a nudge left and a nudge right with all the mechanical designs I could come up with).
Thing is, the latest future pinball actually has a nudgex nudgey option (i'm guessing to feed it analog input from a stick or accelerometer, but I'm not sure yet, just happened to notice it on the config screen).
Kevin Mullins
    • Me on Myspace
« Reply #6 on: February 20, 2009, 03:57:50 pm »
Ah.... I hadn't messed with Visual Pinball or the likes in a looooong time.
I didn't realize that it even had a distinct "left' or "right" nudge.... just figured a nudge was a nudge. But it makes sense now that you mention it.
« Reply #7 on: February 20, 2009, 04:33:33 pm »
Yeah, Future Pinball even has a Nudge Up, no nudge down though, guess that's more or less impossible :)
My prob is getting the dang wiimote to sync easily. Just not happening consistently. That's why i'm thinking the phidgets usb version might be better in this case (it's just a lot of $$ for a one trick pony).
RandyT
  • Last login:April 19, 2026, 05:23:14 pm
    • GroovyGameGear.com
Kevin Mullins
    • Me on Myspace
« Reply #9 on: February 20, 2009, 06:43:06 pm »
Don't see those too often..... didn't even think about the double button idea.  :cheers:
Spinach
« Reply #10 on: February 21, 2009, 12:45:46 am »
OK.  Those ideas are way cooler than mine by far.  And here I thought I was on to something.
Of course, that does leave me with more to think about and add on.
Ummon
  • Trade Count: (+13)
« Reply #11 on: February 21, 2009, 07:54:20 pm »
VP, of course, has always had left, right, and up.
Yo. Chocolate.
Stephen Hawking
« Reply #12 on: February 21, 2009, 09:42:03 pm »
Hadn't seen that idea using the carpeting for a spring. Pretty interesting. I have the pinball elements integrated into my actual control panel, so that'll take some rethinking to work into what I'm doing.
But I do like the idea. It's nice, simple and works with standard, easy to come by components.
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
« Reply #13 on: February 22, 2009, 03:20:23 am »
I am using an WiiMote in my Future Pinball cabinet for nudging.
