Author Topic: NEED HELP on how to set up IPAC 2 in MAME ?  (Read 12986 times)
DjLooter_951
  • Last login:May 13, 2009, 04:57:01 pm
  • WHAT IT IZzz!!!
« on: February 13, 2009, 09:35:00 am »
How to set up my IPAC 2 in MAME :dizzy:
Got the CP all wired up first time using the ipac in MAME.
What CTRL File do I use?
Please Help.
GAME OVER
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
Re: NEED HELP on how to set up IPAC 2 in MAME ?
« Reply #1 on: February 13, 2009, 09:44:27 am »
Shouldnt you download the program from Ultimarc, WinIPAC Interactive Panel Designer http://www.ultimarc.com/download.html?
That should get you started!
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #2 on: February 13, 2009, 04:20:01 pm »
It should be set up already; just hit TAB in MAME, then "General Controls", to map the keys/joys to your needs.
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« Reply #3 on: February 13, 2009, 06:04:02 pm »
Do you not need to send a control file from winipac? i think you can even create your own custom one.
TelcoLou
« Reply #4 on: February 13, 2009, 06:09:26 pm »
 :dunno
All I know is that I wondered the same thing after getting mine, pre-installed (got a CP from arcades-r-fun), and e-mailed them. Jack responded stating that it should work "out of the box", and sure enough, it did.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #5 on: February 13, 2009, 07:16:13 pm »
Have you plugged it in ? Are you having specific problems ?
It should work out of the box with MAME (exception for P3 and P4 keymaps, which don't apply here).
Working: Not Enough
Projects: Too Many
Progress: None
DjLooter_951
  • WHAT IT IZzz!!!
« Reply #6 on: February 13, 2009, 09:05:34 pm »
Yes I have plugged it in and it was set up for X-Arcade not all the buttons worked, but I am going to try it out in standard keyboard.
(QUOTE FROM ULTRIMAC
Do I have a lot of setting up to do before playing?
NO. Using the key-code programming is entirely optional. When the board is shipped, all codes are automatically assigned to MAME standard keys. As many people have found, this makes installation very quick and easy.
GAME OVER
CheffoJeffo
« Reply #7 on: February 13, 2009, 09:27:13 pm »
Sorry -- I didn't mean to be a smartass ... the problem just wasn't clear to me.
Working: Not Enough
Projects: Too Many
Progress: None
TelcoLou
« Reply #8 on: February 13, 2009, 09:29:04 pm »
You could open up notepad, and see what button presses "type" in the .txt document, to see for sure whay keys are bound to what input.
DjLooter_951
  • WHAT IT IZzz!!!
« Reply #9 on: February 13, 2009, 11:17:40 pm »
No problem I never took it that way ;D
But I did try it out in MAME, like ULTRIMAC stated to set it up in MAME everything worked except player 2 buttons 5,6, & 7 had to be set up manually in MAME 125, for some reason those buttons where not assign to anything ???
« Last Edit: February 14, 2009, 12:12:38 pm by DjLooter_951 »
GAME OVER
TelcoLou
« Reply #10 on: February 13, 2009, 11:28:03 pm »
But I did try it out in MAME, like ULTRIMAC stated to set it up in MAME everything worked except player 2 buttons 56 & 7 had to be set up manually in MAME 125, for some reason those buttons where not assign to anything ???
Standard issue; those keys for some reason are not mapped by default; 'tis a MAME thing  ;)
Marky_1979
    • Personal Webspace
« Reply #11 on: February 14, 2009, 09:53:04 am »
Do you know if an ipac and a jpac can be used together? I have a standard 2 player c/p and want to also use my electronic coin door. I know the ipac would be connected via a ps2 cable but what about the jpac?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #12 on: February 15, 2009, 07:22:23 pm »
Yes these can be used together in any combination of PS/2 or USB.
Normally you would need to re-program one board for all different keycodes from the other board.
