Author Topic: Where can I find these connectors?  (Read 2176 times)
« on: January 06, 2009, 11:26:42 am »
What are they called, and does anyone know a part number, etc?
Necro
  • Last login:December 31, 2025, 03:36:17 pm
Re: Where can I find these connectors?
« Reply #1 on: January 06, 2009, 12:40:44 pm »
They are molex connectors.  And where to get them depends on their configuration - I believe that you will need to get ones that match both the number of connectors AND the shape configuration of those connectors (the plastic shape).
The name should at least get you moved forward a bit.
(And, just in case, these aren't meant for multiple connect/disconnects...if your thinking of using them for that you might want to check DB cables/connectors instead...)
mrclean
    • Guscade
« Reply #2 on: January 06, 2009, 12:41:29 pm »
yeah that's called a "Molex connector" you can go to mouser.com and when you search type in molex connector, then hit square 3,xxx will come up you can apply a filter so do 3 rows 12 contacts etc.. not sure if this is it but i found this when i applied the filter : http://www.mouser.com/Search/ProductDetail.aspx?qs=kJlCKCzaZTNJpzTiuuhJQQ%3d%3d i'm sure they have the molex connector you need
2,370,650 Gun.Smoke
ghettodish
  • Last login:October 21, 2017, 03:41:58 pm
« Reply #3 on: January 06, 2009, 01:20:48 pm »
Fry's sells them if you have one close by.
Ummon
  • Trade Count: (+13)
« Reply #4 on: January 07, 2009, 07:25:51 pm »
He does. But in bulk, they might likely be cheaper online.
Yo. Chocolate.
Stephen Hawking
« Reply #5 on: January 11, 2009, 08:15:50 am »
Nope, not Molex connectors...
These are AMP connectors, maybe the MATE-N-LOK?
« Last Edit: January 11, 2009, 08:28:56 am by HarumaN »
« Reply #6 on: January 11, 2009, 08:30:02 am »
The male side looks like this:
Ken Layton
  • Guru
  • Technician
« Reply #7 on: January 11, 2009, 12:30:09 pm »
Looks like Molex "mini-fit" connectors.
« Reply #8 on: January 11, 2009, 12:41:10 pm »
The connectors are stamped with AMP, though.  As in AMP / Tyco electronics, I think.
Ken Layton
  • Guru
  • Technician
« Reply #9 on: January 11, 2009, 01:18:33 pm »
Ah, then these are AMP/Tyco "Mini-Universal Mate-N-Lock" or "Mate-N-Lock II" connectors. Mouser has those.
« Last Edit: January 11, 2009, 01:28:56 pm by Ken Layton »
« Reply #10 on: January 29, 2009, 04:10:26 pm »
Found out these are Tyco / AMP Universal Power connectors, parts # 176299-1 and # 176298-1
The pins that go inside are part # 175149-1
Got them in my hands today, and verified that they match.  :cheers:
