Author Topic: Best way to remove old side art  (Read 9147 times)
_JMFR
  • Last login:December 02, 2009, 01:54:50 am
« on: December 29, 2008, 02:36:42 pm »
What is the best way to remove old side art without damaging the cabinet?
daywane
  • GRRRR!
Re: Best way to remove old side art
« Reply #1 on: December 29, 2008, 08:22:09 pm »
me... I just use a belt sander
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: December 29, 2008, 08:54:50 pm »
I used a heat gun (or you could use a hair dryer) and started at one corner and worked it from there.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: December 29, 2008, 09:03:56 pm »
Depends on the  sideart -- stencilled, screened, sticker ?
Are you planning to refinish the exterior or do you just want the sticker gone ?
Working: Not Enough
Projects: Too Many
Progress: None
cmoses
« Reply #4 on: December 29, 2008, 11:59:36 pm »
Not trying to hijack, but have similar question.
I have a MKII Cabinet that appears to have vinyl sticker on front and sides, but they have been painted over in black paint.  I want to smooth the surface down and repaint.  Am I best to try to remove the vinyl sticker or just patch and holes/damage and then sand it all and repaint over top?
Any suggestions welcome.
_JMFR
« Reply #5 on: December 30, 2008, 03:29:12 am »
^^ INTRUDER!!!!! :angry: haha.... it's sticker side art..ill give the blowdryer a try.
I too got a mk cabinet...mines umk3..some dumbass painted over the art,but u could still see it thru the paint..not to mention a ton of runs. WHY WOULD SOMEONE DO THAT!!!!!!
im sure this question has been asked...but where the hell can i buy new mk3 art?
_JMFR
« Reply #6 on: December 30, 2008, 03:31:25 am »
i plan on refinishing...im gonna have an artist friend of mine paint it for me...
CheffoJeffo
« Reply #7 on: December 30, 2008, 08:13:06 am »
Then I would use a heat gun and Super DeGooper to remove the side art prior to sanding the sides for paint, although the belt sander would likely take care of it too!
Working: Not Enough
Projects: Too Many
Progress: None
daywane
  • GRRRR!
« Reply #8 on: December 30, 2008, 09:00:14 am »
I have tried 3 differant paint strippers.
1 thing,  the stuff is not cheap. It takes close to a Gallon each side.
the only problem with the belt sander with the sticker.
It will gum up a belt fast.
I think I used 6 belts up.
Belt sanders are not as bad on wood as people here think.
CheffoJeffo
« Reply #9 on: December 30, 2008, 10:00:21 am »
I typically only use a paint stripper if I am trying to save the underlying artwork (and then use something mild like Safest Stripper).
Otherwise I am a heat gun guy -- if you own the heat gun, it is cheaper (and, to my experience, faster) than any alternative.
The Super Degooper I use only for glue residue.
Working: Not Enough
Projects: Too Many
Progress: None
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« Reply #10 on: December 30, 2008, 10:09:05 am »
Regarding mk2 I have restored 3 of them that were painted black. - filled the holes sanded all bmps and repainted a primer coat. They all turned out beautiful
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
cmoses
« Reply #11 on: December 30, 2008, 10:20:40 am »
Ctozzi,
That is the approach that I am initially taking.  Started filling holes over the weekend.  Also repairing some damaged edges and corners.  Did you hand sand, or use a palm sander?
  • Last login:April 18, 2026, 05:46:43 pm
« Reply #12 on: January 28, 2009, 11:53:54 am »
I'm about to attempt the hair dryer method on my DK... assuming it ever warms up enough.  Is this the best method?
stan2323
  • Last login:April 10, 2026, 07:02:05 pm
  • Major Retired USS Enterprise Commanding
    • My home page
« Reply #13 on: January 28, 2009, 12:49:14 pm »
Heat gun and pealing off the old art is how I got my old Tron art off.  It took about an hour each side.  Then Goo Goon for the residue.  There was not much residue as I pulled slow and went easy.
Stan
Careful what you wish for you may get it!!
There are 10 kind of people in the world those that understand binary and those that do not!!
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« Reply #14 on: January 28, 2009, 12:50:45 pm »
I used the hairdryer technique on my Galaxian.  Word of caution:  wear thick gloves.  Till I was done, I think I melted off my fingerprints and my fingers were burnt for a day or so.
-csa
stan2323
    • My home page
« Reply #15 on: January 28, 2009, 01:38:33 pm »
-csa
I too learned this lesson the hard way.  But I did not think to wear gloves.
Stan
« Reply #16 on: March 21, 2009, 08:28:59 am »
Well, today is the day... it's like 35 degrees out right now but it is supposed to warm up to around 55 so I'm going to try and remove the side art from my DK.  I don't have a heat gun but I do have a hair dryer - well, my wife does  >:D - so I guess I'm going o give that a try and clean up with Goo Gone or something is I have to.  Then it is on to bondo, sand and paint!  I'm hoping to get the thin primed today but I've got a lot of work to do!
mrclean
    • Guscade
« Reply #17 on: March 21, 2009, 10:49:13 am »
first I used one of these:
Then for the rest I used paint thinner took 2 coats on each side
And once I could see the bare wood I then used my palm sander
Then used wood filler / Primer / Paint
« Last Edit: March 21, 2009, 10:58:54 am by mrclean »
2,370,650 Gun.Smoke
Sir Headless VII
  • Last login:April 30, 2017, 02:04:52 pm
« Reply #18 on: March 21, 2009, 11:31:33 am »
Mame Marquees.com seems to have it
« Reply #19 on: March 21, 2009, 01:14:07 pm »
I just finished.  Took about 2 solid hours.  I still have to remove the glue with goo gone but the hair dryer did the trick.  I scraped with the end of a flat head screwdriver and when I got enough to grab onto I started peeling.  What a pain!
I've never used Goo Gone before (I have to go buy some). Do you just let it sit and then everything rubs right off or does this take some elbow grease to do right?
EDIT: mrclean: my side art/cabinet side isn't quite in as bad shape as your started out (nice job).  The DK cab appears laminated or something - it is very slick.  It sucks I have to sand and paint over it.
« Last Edit: March 21, 2009, 03:05:07 pm by javeryh »
« Reply #20 on: March 21, 2009, 03:06:36 pm »
I just finished one side - what a huge pain in the ass!!  It took over an hour to get all the glue off but it looks pretty good.  I'm taking a little break before I tackle the other side.  I had high hopes for today's progress but I'll be lucky to get to the bondo at this rate!
