Author Topic: Messy holes  (Read 4343 times)
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
Messy holes
« on: November 26, 2008, 06:52:33 am »
Hi all,
My first attempt at drilling through plastic on my net city cab has been a bit of a disaster. I need something to fit between the happ competition buttons and the plastic panel itself to hide the sloppy cuts (i.e. holes are slightly oval and you can see a gap when button is fitted.)
Any suggestions? I normally drill wood and get it spot on.
Dexter
somunny
  • Is it hot in here?
Re: Messy holes
« Reply #1 on: November 26, 2008, 07:31:27 am »
Dremel out the hole in a joystick washer?
SirPeale
  • Green Mountain Man
Re: Messy holes
« Reply #2 on: November 26, 2008, 07:32:48 am »
Not possible to start over?
Did you clamp the plexi down when you drilled?
Franco B
Re: Messy holes
« Reply #3 on: November 26, 2008, 07:39:38 am »
Could make you some button bezels.  Any width/diameter/bore etc.
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
Re: Messy holes
« Reply #4 on: November 26, 2008, 07:48:53 am »
^^^ Those look nice.
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
Statsman1
  • Last login:October 20, 2024, 07:03:57 pm
Re: Messy holes
« Reply #5 on: November 26, 2008, 08:55:15 am »
I had the same problem drilling the button holes through 3/4" MDF - I thought I'd be smart and drill from the back, but when it went through the front, it split some of the MDF away from the spaces in between the holes.
I had nothing to lose, so I threw in some of this really thin spackle stuff, let it dry, sanded it, did it again, and it worked out very nicely.  It was 2 days from first spackle to finished.
I was just too stubborn to give up on the CP board, even though it looked ugly.
Necro
  • Last login:December 31, 2025, 03:36:17 pm
Re: Messy holes
« Reply #6 on: November 26, 2008, 09:30:56 am »
Stats, did you drill through the MDF into something else? (have a backing board) when you did this or just a cut to open air?
Ginsu Victim
  • Last login:Yesterday at 12:35:01 am
  • Comanche, OK -- USA
Re: Messy holes
« Reply #7 on: November 26, 2008, 09:34:56 am »
My suggestion was going to be:
Talk to Franco B.
He got here first. ;D
Check out my first product, The Tone Ledger, a premium workflow tool designed for guitarists, bassists, keyboardists...pretty much anyone who enjoys using amps and pedals.
CCM
Re: Messy holes
« Reply #8 on: November 26, 2008, 09:46:21 am »
Hi all,
Dexter
hmmm, this wasn't what I was expecting when I read the title...
Statsman1
Re: Messy holes
« Reply #9 on: November 26, 2008, 09:55:26 am »
I cut into open air - braced on a worktable, but I drilled down into open space below the board.
I suppose a backing board would have helped too.  I wanted to make sure I wasn't leaning full-force on the drill when it went through (my first arcade cabinet, I did that, and my whole arm went through it and blew it to smithereens.), so I probably wasn't doing it 100% correctly from the beginning.
I did learn, though, that once the tip of the spade bit goes through the other side, to flip the board over and complete the hole from from the front.  That seemed to help.
A backing board would have been the smart thing, now that you mention it.
Re: Messy holes
« Reply #10 on: November 26, 2008, 10:20:27 am »
Wow you ain't kidding.  I dig it.
Ginsu Victim
Re: Messy holes
« Reply #11 on: November 26, 2008, 10:22:54 am »
Yeah, I hope he didn't google "messy holes" before asking here.
Necro
Re: Messy holes
« Reply #12 on: November 26, 2008, 12:06:23 pm »
Same, was pretty sure this belonged in EE and was NSFW. ;)
PsychoAU
  • Last login:October 04, 2020, 12:27:19 am
Re: Messy holes
« Reply #13 on: November 27, 2008, 11:05:08 am »
That's what she said?  eh, I got nothin'
« Last Edit: November 27, 2008, 11:10:04 am by PsychoAU »
Dexter
Re: Messy holes
« Reply #14 on: November 28, 2008, 06:54:24 am »
Cheers peeps,
It wasn`t the panel, its  the lower control box so theres no way to use a backing board!
PMing francob. Cheers man!
