Author Topic: Lighted Control Panel Overlay Surface  (Read 2774 times)
whynotpizza
  • Last login:March 23, 2025, 10:01:28 am
« on: November 21, 2008, 11:32:17 pm »
Ok, bunch of questions lately on lighting. :)
Anyone know what would workk best to try and get the lightning bolt in my control panel overlay to "light-up" in the dark?
http://www.mamemarquees.com/blue-lightning-control-panel-from-p-194.html
Should I paint the surface with luminescent paint? Use a black-light?
Any way to get light to be trapped (and light-up the bolts) between the overlay surface and the lexan which will be placed on top?
Any ideas are welcome. :)
  David
Missile
  • Last login:April 13, 2009, 09:02:32 pm
Re: Lighted Control Panel Overlay Surface
« Reply #1 on: November 22, 2008, 01:11:35 am »
My car has a tiny little LED on the rearview mirror to light up the shifter area.  I'm thinking about putting a couple of those hidden by the bottom of my overhead marquee on the build I'm working on to accomplish a similar effect.  My car doesn't require more than a 1/4" hole for its shifter light.
Just a thought.
« Last Edit: November 22, 2008, 01:13:12 am by Missile »
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #2 on: November 22, 2008, 09:56:27 am »
odd...does your car have a light to illuminate the clutch/brake/& gas pedals too...?
who looks at the shifter to shift...?
 :dizzy:
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: November 22, 2008, 09:59:57 am »
My 08 Honda CR-V has the same blue light thingy.
erictrumpet
  • Last login:February 17, 2016, 11:59:23 am
« Reply #4 on: November 22, 2008, 10:32:21 am »
David, you may have answered your own question - if you got some special white paint from here http://www.blacklight.com you could paint it on the lightning bolt with a tiny little pinstriping brush, and in normal light it would appear normal but under a blacklight it would glow like frickin crazy! I've thought about putting a blacklight in the speaker areas of my cab (in the underside of the marquee overhang) - at that website, they also have many different blacklight bulb types, so I thought of making a recessed "spot" light blacklight to shine from above and bathe the cp in spooky glowiness. :)
Eric.
Sardu
  • Last login:April 08, 2023, 05:45:54 pm
« Reply #5 on: November 22, 2008, 10:38:05 am »
I wonder if 3/4" or 1" thick plexiglass like the stuff found here:
http://www.estreetplastics.com/
could be used as a CP.  Then you just add a light inside like a lightbox.
Or get your overlay printed with glow in the dark paper or ink
Ginsu Victim
« Reply #6 on: November 22, 2008, 11:32:33 am »
Sardu - Maybe you should have a signature that says, "Not THAT Sardu"
If you don't know what I'm talking about, look up NESticle, Genecyst, and Callus. (Oh, and Bloodlust Software)
whynotpizza
« Reply #7 on: November 22, 2008, 11:54:38 am »
Good suggestions guys, although I was thinking along the following lines and using a lighted ON or OFF system.
Check this stuff out: http://www.elbestbuy.com/2hibrperfo.html
It would require me cutting a 2.3mm groove in the lightning bolts using some sort of dremel or router (very careful is the word!)  :)  but then I could turn ON or OFF as needed. I also like the fact that I am not using a BLACKLIGHT - those things get into your eyes and bother you I seem to recall, but maybe not.
Ah the choices are endless and will certainly take time to work thru testing the options!
As a side note, the link above also sells this LIVE TRACK system which really looks cool to add around the cabinet for detailing.
  http://www.elbestbuy.com/newlwimosy.html
Sardu
« Reply #8 on: November 22, 2008, 12:35:24 pm »
haha, yep.. I remember him.  Wasn't it rumored that we went to work for EA or something?
Anyway, been using "Sardu" from "Bloodsucking Freaks" movie on various sites, games, etc, since '98.   ;D
Tim N.
  • Last login:December 06, 2016, 04:49:21 pm
    • RalphWiggum dot Net
« Reply #9 on: November 22, 2008, 10:29:53 pm »
David, you may have better luck with EL Tape rather than EL line... Have a look at some of the work here-
http://electroluminescence-inc.com/howtouseEL.htm
The tape is going to be much flatter and would fit between the artwork and Plexi rather easily...
fixedpigs
« Reply #10 on: November 23, 2008, 10:39:24 am »
Missile
« Reply #11 on: November 23, 2008, 09:26:12 pm »
 :dizzy:
Just a standard feature on my vehicle, I didn't put it there or anything  ;)
Hey whatdya know, I found a pic.  As I said the little LED is built into the rearview mirror so that part isn't visible, but you can get a good idea of the effect.
« Last Edit: November 23, 2008, 09:34:15 pm by Missile »
