Author Topic: trackball lighting  (Read 2386 times)
clickhea
  • Last login:August 09, 2019, 07:33:40 am
trackball lighting
« on: October 12, 2008, 05:47:43 pm »
I need a better solution other than litemite.  I dont like how far down the led sits i feel like alot of the light is wasted.
also, id like a white led light to lightup the blue 3" highball.
i dont see anything on groovygamegear.. unless iam over looking it.
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
Re: trackball lighting
« Reply #1 on: October 12, 2008, 06:01:24 pm »
If you don't need it to blink or change colors, these "Lazer" LED clusters work great:
$3 here: http://www.svc.com/lzled3blu.html
"Some drink from the fountain of knowledge; I only gargle."
clickhea
« Reply #2 on: October 12, 2008, 06:03:04 pm »
how do you attach that to the bottom of the trackball?
RandyT
  • Last login:Today at 05:23:14 pm
    • GroovyGameGear.com
« Reply #3 on: October 12, 2008, 06:08:00 pm »
Send me an email.  I have a new NOVA trackball lighting module that should do just what you want.  Bolts right up to a HAPP or Imperial Trackball using the existing light fixture mounting hole.   BTW, a blue light is much better than white to light up a blue trackball.
I really need to get this new stuff on the store.... :P
RandyT
clickhea
« Reply #4 on: October 12, 2008, 06:12:19 pm »
sounds good to me i'll take it
email sent  :burgerking:
« Last Edit: October 12, 2008, 06:13:59 pm by clickhea »
Andymac1990
  • Last login:November 04, 2008, 04:27:22 am
« Reply #5 on: October 13, 2008, 05:23:28 pm »
Hi I have a 3" High-Ball Trackball w/Harness, Blue Translucent from Happ.com wired to an OptiPac. What would you suggest lighting wise? It sounds like a bright blue led would work great. It would need to be able to be wired to my 5volt Optipac.
RandyT
« Reply #6 on: October 14, 2008, 01:46:15 pm »
The same thing as above, assuming that the High-ball model has a similar light mounting configuration to the others.  I'm guessing it's the same base, so it probably does.   You'll need to come up with a cable to get the power from your interface.  Alternatively, you can send me a pic of what you are plugging it into (pinout) and I could likely make a special version for you at an additional cost.
RandyT
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
« Reply #7 on: October 14, 2008, 02:01:59 pm »
RandyT
I plan on making a substantial purchase soon from you, what is missing from the store?
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
Andymac1990
« Reply #8 on: October 14, 2008, 08:21:14 pm »
I can do all the wiring my self. Its pretty simple I just need a light. Ill try to get a pic
DrumAnBass
« Reply #9 on: October 14, 2008, 10:14:18 pm »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #10 on: October 15, 2008, 12:13:04 pm »
... 3" High-Ball Trackball ... Happ....
... assuming that the High-ball model has a similar light mounting configuration to the others.  I'm guessing it's the same base, so it probably does....
Yes, all happs 3" TBs use the same part for the bottom half of the case.  The old atari 3" TBs should be exactly same too, but I don't own one of these old TBs, so I can't verify it.
FWIW, the only difference is the top half of the base.  Well, okay, and the sensor boards, old arcade green vs new arcade red vs USB.
Robin
Knowledge is Power
RandyT
« Reply #11 on: October 15, 2008, 12:46:35 pm »
Thanks for the verification!  That's good to hear.
FWIW, I also have an old WICO here that looks like the Imperial as far as the lighting is concerned, so that should be covered as well.
I'll try to get some pictures of the new lighting board for those who might be curious.
RandyT
RandyT
« Reply #12 on: October 15, 2008, 03:52:28 pm »
We had a few of these going out today, so I snapped a photo before they were packed up.
The one on the left is the single color version with the mounting hardware inserted in the "Imperial / WICO" position, and the one on the right is the RGB version with the hardware in the "HAPP / Atari" position.
These are using the NOVA light sources, so they are wide angle and each LED is the equivalent of 5 "superbrights".  That's the same as 5 and 15 superbright LED's respectively.
RandyT
clickhea
« Reply #13 on: October 15, 2008, 07:47:54 pm »
i seen mine was shipped out today i cant wait to get it
i'll take some pics when i have it installed
DrumAnBass
« Reply #14 on: October 16, 2008, 02:25:29 pm »
Nice Randy!  How much?
