Author Topic: trying to have a coin register a credit but ends up in the return slot Non MAME  (Read 2317 times)
mrclean
    • Guscade
I have a JAMMA harness and have connected it to this :
The good news is i know it's sorta working to a degree. If i manually click it down with my finger to complete the circuit in game it activates a credit. I was curious as to how to fix my 25 cent coin from keep ending up in the return slot instead  of hitting that metal wire to register a credit. So i think it's a matter of fixing the coin from taking a different path, how do i tackle this issue ?
more pics of my coin mechs :
5301-10 seems to look like a part number don't know if that helps
« Last Edit: September 28, 2008, 12:54:47 am by mrclean »
2,370,650 Gun.Smoke
Maybe the coin slot accepts tokens and not quarters?
What he said.
Probably .984" tokens.
mrclean
    • Guscade
can i change it back to quarters ?
2,370,650 Gun.Smoke
Ginsu Victim
  • Comanche, OK -- USA
Just change out the coin mechs.
mrclean
    • Guscade
how do I do this, and where can i purchase them from , oh yeah and ginsu, i'm getting close but i think i had a bad JAMMA harness i got all my buttons functioning with the exception of "fire right". So i think i need to get a different harness. I hope it was a bad JAMMA harness. It could be the PCB, or could be the Capcom Classic to JAMMA Adapter I'm not sure.
« Last Edit: September 28, 2008, 11:09:08 am by mrclean »
2,370,650 Gun.Smoke
SirPeale
  • Green Mountain Man
I'm reading this right, you're trying to get a quarter to give you credits, but when you drop a quarter it ends up in the reject, is that correct?
If it is, you need quarter mechs.  Likely you have token mechs.  I have some brand new Happ mechs for $15 plus shipping, or some used ones for $5.00 each plus shipping.  It's just a matter of removing the old mechs and putting the new ones in their place.
Ken Layton
  • Guru
  • Technician
If the "lockout coils" are not energized then all coins inserted will be rejected to the coin return hole.
5301-10 should be a US quarter acceptor.
Appears you have this door:
http://arcarc.xmission.com/PDF_Coin_Mechs_Etc/Coinco/Coinco_2802_Series_Game_Door.pdf
mrclean
    • Guscade
yeah that looks like an exploded view , so ken how to i fix this issue ? or energize the coil ?
2,370,650 Gun.Smoke
SirPeale
Bloody hell...can't believe I missed that.
You can just remove those lockout coils.  Just tie the wires to the side.
Let me guess: converted Atari cab?
cmoses
Could be an Taito cabinet.  That is the same door I have one mine.  I have not fully gotten to my door yet, but the best I can tell is that you can power them up just like the lights.  Someone can probably verify if they need 12V or 5V.  Once they receive juice, then they will let the quarter through.  They are in place so if anyone drops in a quarter while the machine is off, it just falls into the coin return.
mrclean
    • Guscade
wow cool good to know and yes it is a taito cabinet, my 12v is running to my JAMMA harness, where exactly does the 12v / 5v or whatever i need plug into on that coin door ? Initially when i got this machine the coin doors did light up, but i have removed many of the older wires, because i installed a new jamma harness
« Last Edit: September 28, 2008, 08:56:36 pm by mrclean »
2,370,650 Gun.Smoke
cmoses
I am using a computer and computer power supply, so I just tapped into an extra line to get the 12V, not sure on the best way to get it for a Jamma cabinet.
Just curious, since I am working with a Taito as well.  Do you have a project page?  Any pictures of what you have done?  What was the cabinet originally?
Here is the link to mine:  http://forum.arcadecontrols.com/index.php?topic=82903.0
I am MAMEing mine, but it was a Taito that was converted to a 1943 Battle of Midway, so it had already been converted and was in pretty bad shape.  Just curious as to what others are doing.
mrclean
    • Guscade
No i don't have a project page as of yet, but it is certainly a project. Honestly I have no idea what taito game it originally was, could of been a zoo - keeper, jungle hunt, elevator action etc. I'm converting mine to a Dedicated Gun.Smoke machine to get the world record hopefully. I basically liked the shape of the taito cab for the Gun.Smoke machine specifically because of the monitor orientation. Most Gun.smokes were inside pac-man conversions, however i felt that the monitor is too flat in terms of game play , and the other conversions are more often found in centipede / dig-dug machines where as that is a direct view. I really like the taito cab because the monitor oriention is in between the two of them, it all comes down to personal prefrence of course.  I have seen one taito Gun.Smoke machine I really like the way it looks.
On another note, i think my JAMMA Harness is bad, or my capcom classic to JAMMA adapter is bad, or possibly the pcb... Not sure i'm trying to figure it out. As far as functionality without hooking up buttons, rather testing wires i have all the functions I need with the exception of "Fire Right". I think it's the JAMMA harnes, but again could be of the others ive mentioned.
Oh yeah peale how do i do this :
is that going to fix /  have the coin fall onto that metal wire , and issue a credit? because someone else said that i need power on the coin door or else it won't accept coins
« Last Edit: September 29, 2008, 12:00:08 am by mrclean »
2,370,650 Gun.Smoke
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
My coin mechs look something like those, and they are just plastic, no place to hook up
power. I do have problems with one of them. Sometimes it'll accept a quarter, sometimes
it ends up in the coin return slot. The other one, which is identical, works good most of
the time.
