Author Topic: Do they make a Player one button that doesn't rub away or always remains ?  (Read 4460 times)
mrclean
    • Guscade
So i have a player one button from happ, and at first it had a tiny spec, which then grew to the guy looking like he got shot, which was funny for a little while.. and then pretty much completely rubbed off and it's now solid white. Any ideas as to or does such a thing exist where i can get a player one button white, to look like the happ one without it fadding away / rubbing off ? Any one else experience this ?
2,370,650 Gun.Smoke
protokatie
Re: Do they make a Player one button that doesn't rub away or always remains ?
« Reply #1 on: September 23, 2008, 11:45:54 pm »
Shizzle happens.. In the future, try clear coat nail polish on the top. You may have just gotten a bad batch tho.
mrclean
    • Guscade
« Reply #2 on: September 23, 2008, 11:52:50 pm »
that's a really good idea, but i was thinking that maybe some vendor would have a custom button? or beneath / under the plastic metal player 1 figure perhaps ?
2,370,650 Gun.Smoke
protokatie
« Reply #3 on: September 24, 2008, 12:13:59 am »
Your sentence is non-diagramable: But from what you are asking, there do exist clear buttons and you can buy "under-lays" for those buttons. Try Ultimarc.com. Andi has some clear buttons with inserts. The buttons are meant for lighting, but could be used for protecting the image.
EVEGames
  • Last login:December 03, 2025, 10:06:10 pm
« Reply #4 on: September 24, 2008, 12:14:37 am »
How about this, Clean: PGI?
Haven't used them myself, but I bet they don't wear off  :)
protokatie
« Reply #5 on: September 24, 2008, 12:43:59 am »
Here I go trying to get the high score with Andi, and you throw in GGG stuff...
Oh wait... I might want to befriend Randy as well..
* protokatie hands randy a cheeseburger
yeah, I know, it is an old joke....
kagaden
  • Last login:September 10, 2022, 10:58:37 pm
« Reply #6 on: September 24, 2008, 02:34:46 am »
my black one player button did the exact same thing within a week of heavy use. Strangely the 2 player button that gets just as much love seems intact.
Cheap... I'm getting a new one and coating it.
Franco B
« Reply #7 on: September 24, 2008, 03:22:13 am »
You could always get some vinyl stickers from Pongo.
thatitalian
  • The Revolution Is Coming...
« Reply #8 on: September 24, 2008, 06:39:37 am »
Second the Pongo movement, although Ultimarc P1 buttons are very good and I also really love the PGI inserts! A few very good options.
arzoo
  • Last login:March 24, 2026, 08:14:12 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #9 on: September 24, 2008, 08:24:29 am »
Ultimarc makes buttons with inserts under a plastic cap.
Ultralux
Robots will kill you.
Arcade Addiction
massive88
« Reply #10 on: September 24, 2008, 09:24:09 am »
I had the same thing happen and got Vinyls from Pongo, worked great since, plus I was able to add labels to my pause and coin buttons.
« Last Edit: September 24, 2008, 09:30:26 am by massive88 »
  • Last login:Yesterday at 05:46:43 pm
« Reply #11 on: September 24, 2008, 10:52:26 am »
I was going to post the exact same thing.  These will never rub off:
mrclean
    • Guscade
« Reply #12 on: September 24, 2008, 01:06:05 pm »
All really good ideas, i don't want to change the feel or look of the button so i think pengo is probably the way to go for me it seems
2,370,650 Gun.Smoke
fjl
  • Pixels Rule!
« Reply #13 on: September 24, 2008, 02:47:50 pm »
But they can accidently peel off couldnt they? Or did you cover it with some transparent nail polish? Crazy glue?
Franco B
« Reply #14 on: September 24, 2008, 02:51:28 pm »
I can't see them accidentally peeling off unless you get your nail under them and try to peel them off. If you make sure that the button is perfectly clean before applying them then they wont be going anywhere.
« Reply #15 on: September 24, 2008, 03:07:18 pm »
Exactly.  I used a q-tip and rubbing alcohol to clean the surface of each button before applying the decal.  The back is VERY sticky (you get one shot at the application) and after burnishing it on there with the tip of a flat head screwdriver there's no way they are coming off.  Also, the decals are cut from a sheet so the sticky backing covers the entire bottom surface - you would have to actually pick at it in order for them to come off.   :cheers:
mrclean
    • Guscade
« Reply #16 on: September 24, 2008, 05:25:42 pm »
how much are they ? can't be too pricey
2,370,650 Gun.Smoke
« Reply #17 on: September 24, 2008, 05:35:18 pm »
Just PM Pongo and he will give you a quote.  I think I paid $10 shipped for mine.
