Author Topic: Playing Smash TV with 2 UltraStik 360's  (Read 2006 times)
TexFlood
  • Last login:March 02, 2021, 07:37:29 pm
« on: September 14, 2008, 04:53:43 pm »
I'm assuming someone out there is running Smash TV with two 360's...
How do you configure this to happen?   :dizzy:
I've looked at the Input (this game) options when running the game, but it seems to only list the controls for 8 options for Player 1 and 8 options for Player 2....
Can someone explain how they made this work?
Ginsu Victim
  • Comanche, OK -- USA
Re: Playing Smash TV with 2 UltraStik 360's
« Reply #1 on: September 14, 2008, 06:05:47 pm »
Smash TV, Total Carnage, Robotron, and a handful of others used two sticks. The controls for player one will be labeled as LEFT/UP, LEFT/DOWN, LEFT/LEFT, LEFT/RIGHT, RIGHT/UP, RIGHT/DOWN, RIGHT/LEFT, and RIGHT/RIGHT. The first part of each of these directions indicates the stick to be used. LEFT/UP means LEFT stick (player 1 side), direction UP. Make sense?
TexFlood
« Reply #2 on: September 14, 2008, 07:46:16 pm »
I had to read it a couple of times to get it through the thickness of my skull, but it does make sense!  I have Smash TV up and running now with two joysticks!
When you set values in Input (this game) in MAME, how do you set multiple values for an item.  For instance, set a button to "I" or JOY Left?
Ginsu Victim
« Reply #3 on: September 14, 2008, 10:52:40 pm »
Press enter (or whatever you have mapped to allow you to edit the button function), then press I. Without moving off that function, hit enter again, and now hit JOY LEFT.
TexFlood
« Reply #4 on: September 15, 2008, 12:19:56 am »
GV - OK, that works - thanks for all the help!
arzoo
  • Last login:March 24, 2026, 08:14:12 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #5 on: September 15, 2008, 08:19:52 am »
Robotron rocks with two u360s  ;D
Robots will kill you.
Arcade Addiction
Ginsu Victim
« Reply #6 on: September 15, 2008, 08:23:28 am »
Hell yeah, much better than playing with microswitch-based sticks.
Havok
  • Trade Count: (+17)
« Reply #7 on: September 15, 2008, 05:19:57 pm »
But plays better with two P360s.
DaveStall
  • Last login:February 19, 2021, 05:56:25 am
« Reply #8 on: September 15, 2008, 06:12:06 pm »
Yep, I'd have to agree with that statement.  I have an original Robotron in my basement, and if my Wicos ever bite the dust, the P360s would most likely be my replacement solution.  I like my U360s fairly well, but they don't feel anything like original Wicos like the P360s do.
Dave
Ummon
  • Trade Count: (+13)
« Reply #9 on: September 15, 2008, 08:46:38 pm »
This was a total 'read the mame info' thread. Anyways.....
Dave
But is that an authenticity thing only, or do they actually play better? The throw of P360s is probably twice as far as the Wicos.
Yo. Chocolate.
Stephen Hawking
Havok
« Reply #10 on: September 15, 2008, 09:37:53 pm »
I have both joys, and even with the medium stiffness spring, the P360 feels more authentic, and I can get better scores with them. Of course, I do also have Kowal's actuators on them as well...
DaveStall
« Reply #11 on: September 16, 2008, 07:19:04 am »
For me it is more of a spring tension issue.  Wicos with good condition grommets are much, much stiffer than the U360s with a medium spring.  The P360 spring tension is much closer to the feel of the Wico sticks.  Robotron is not meant to be played with light sticks IMO.  Your forearms should be burning and your wrists should be sore after a good 5-10 million point game!
Dave
