Author Topic: Which Coin Reject buttons do I need (or Can I modify the Happ ones?)  (Read 3905 times)
BradC
  • Last login:December 22, 2010, 05:56:28 pm
    • My First Arcade Cabinet
I bought two of these for my coin door:
But they don't fit. The coin door I have looks like this. I don't know if you can see from the pictures:
The problem is the little metal piece that holds the post onto the button won't fit through the opening in the coin door bracket to push the reject lever on the coin mech. Anyone know which reject buttons I need and where I can get them? I can take some pics of my door and the problem if that would help.
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
Re: Which Coin Reject buttons do I need (or Can I modify the Happ ones?)
« Reply #1 on: April 02, 2008, 07:49:40 pm »
I'm having the same problem with mine...mine was made by a company called "Coin Controls" I believe they went bankrupt but any info would be helpful. (Looking to buy a new reject button with a 25 cent insert and properly sized)
And also Brad, it would be good if you also said your coin door manufacturer (if you can figure it out)
grbgemen
  • Last login:November 19, 2024, 08:32:58 pm
« Reply #2 on: April 02, 2008, 08:10:42 pm »
looks like the same coin mech. in my williams coin door.  if so then check out lizardlick.com
http://www.lizardlickamusements.com//pages/coin_doors_parts.shtml
Xb0x3r
« Reply #3 on: April 02, 2008, 08:17:17 pm »
OH WOW this helps me out so much! Thanks a lot.
BradC
« Reply #4 on: April 02, 2008, 08:32:03 pm »
I don't know the manufacturer of my door, but thanks a ton grbgemen because I have a feeling that this:
is exactly what I need (along with the springs there.) Those bezels are the ones that I have so I think that's it. The reason I think these are the one is because the coin slot on the side of the button is needed. The Happ ones are blocking that slot on my door.
Thanks a bunch!
Jdurg
« Reply #5 on: April 02, 2008, 08:56:17 pm »
Coin Controls was purchased by Wells Gardner who was then purchased by Happ.  So if you go to Happ's website you can get all of the replacement parts that you need.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
BradC
« Reply #6 on: April 02, 2008, 09:15:23 pm »
I couldn't find those reject buttons however.
grbgemen
« Reply #7 on: April 02, 2008, 09:51:59 pm »
glad i could help.
from the happ website, i imagine these are it:
19)     891-1113-01       Entry/Reject Button 25¢    1+     $5.40
from this page:
http://happcontrols.com/coindoors/8124150011.htm
but there is no picture so i cant be sure.
Ken Layton
  • Guru
  • Technician
« Reply #8 on: April 02, 2008, 11:38:27 pm »
Bradc:
You have a Coin Acceptors, Inc. (a.k.a. "Coinco") model 2802 coin door. Coinco bailed out of the amusement coin door and coin acceptor market over ten years ago. Parts are very hard to find. Go to http://arcarc.xmission.com and download the manuals under the "pdf coin mechs" section.
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #9 on: April 03, 2008, 12:33:27 am »
I can get these parts for you, I have some in stock cheaper than what is listed at happ or lizardlick, pm with happ part # & quanities if you need a quote
thanks
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Ken Layton
  • Guru
  • Technician
« Reply #10 on: April 03, 2008, 12:44:22 am »
Happ does not stock Coinco amusement parts. I believe The Great Amusement Emporium and Competitive Products do.
BradC
« Reply #11 on: April 03, 2008, 12:06:08 pm »
Ken, that is awesome, thank you so much. I have been operating under the assumption that the Happ parts would work for this.
divemaster, I already placed the order with LizardLick. :( However if I find that I'm still missing something, I will definately PM you.
Ken Layton
  • Guru
  • Technician
« Reply #12 on: April 03, 2008, 06:10:15 pm »
Coinco (Coin Acceptors Inc.) and Coin Controls parts may look the same, but they are NOT the same. Coinco parts are made in the USA and are made to US measurements. Coin Controls are made in England and are metric. Plus the actual plastic rod on the reject button is in a different place between the two brands.
BradC
« Reply #13 on: April 04, 2008, 05:49:05 pm »
So did I just mistakely buy the Coin Controls parts for my Coico door? Or were you just explaining why I couldn't find my parts at happ? At this point if these are wrong I'll bust out my dremel and hot glue gun, and make them fit!
Ken Layton
  • Guru
  • Technician
« Reply #14 on: April 04, 2008, 06:35:08 pm »
Coinco and Coin Control parts do NOT interchange. As I mentioned the plastic rod is in a different place and the buttons are different size and shape from each other.
ex_directory
  • Last login:April 10, 2015, 08:54:20 am
  • The only game I ever completed... so far.
« Reply #15 on: April 07, 2008, 05:33:07 am »
I have a two coin controls S10 coin mechs.
I purchase all my coin mech spare parts from swallow amusements, they have quite a lot of spare parts for arcade cabs. Ordering process is via a donate button on a payment page but you will need to contact them first to get a price inc p&p. Guy called Stephen there, seems very helpful, I just ordered some equipment wire from them this morning.
They have the new red rejector buttons for the S10, these may fit?
On a similar note, does anyone know if rejector buttons can be sourced for the coin controls S10 that are clear instead of red?
My kitchen cab is progressing here
Ken Layton
  • Guru
  • Technician
« Reply #16 on: April 07, 2008, 10:36:27 am »
Happ Controls only provides Coin Controls reject buttons in red color only.
BradC
« Reply #17 on: April 12, 2008, 01:25:37 pm »
Well, the reject buttons and springs arrived the other day, and thankfully they're the right size. Woo hoo, something went right for me.
