Author Topic: Have been calling around for glass quotes...  (Read 5548 times)
Avrus
  • Last login:September 07, 2011, 09:17:25 pm
  • Canada
    • The Avrus Arcade Project 'Conquest'
« on: January 31, 2008, 11:53:17 am »
I didn't think getting the glass the cabinet would be this difficult.  I'm going for 1/4" 26" x 27" #14 greylite tempered, and if you can believe it ... so far the cheapest price is from Washington, shipped via FedEx to Calgary.
Wtf?
One of the glass suppliers here quoted me $146.
How could it possibly be cheaper for me to buy it from the US, ship it via Fedex, and still be cheaper (and faster mind you) than local suppliers.
Is there some sort of sand shortage going on that I'm not aware of?  Sheesh.   :banghead:
______________________________
'Conquest' upright 4 player arcade project log:
http://avrus.blogspot.com/
2600
Re: Have been calling around for glass quotes...
« Reply #1 on: January 31, 2008, 12:04:25 pm »
Markups.
We talked about this in a thread a few years ago.  Same thing happens around here.  The places you are calling most likely are getting the glass from somewhere else.  Seems to be the closer you live to a big city the more it happens.  By ordering online, you are cutting out the middleman.
« Reply #2 on: January 31, 2008, 12:15:48 pm »
also -
do you need tempered?
  • Last login:April 18, 2026, 05:46:43 pm
« Reply #3 on: January 31, 2008, 12:17:06 pm »
also -
yeah - I wouldn't get it tempered unless it's for a cocktail cabinet.
Avrus
  • Canada
« Reply #4 on: January 31, 2008, 12:22:09 pm »
Well how much can it add to the price?  I mean so far the cheaper local supplier prices are the same as the price shipped from Washington, only 3 - 4 weeks longer.
2600
« Reply #5 on: January 31, 2008, 12:26:17 pm »
I'd use tempered.  Just not worth the risk and it only adds like $10-$20 more.
If I don't use tempered glass, then I use plexi.
« Reply #6 on: January 31, 2008, 01:32:08 pm »
Really?  Glass shops around me consistently charge 4-5x to temper.  I got a piece for my cocktail cabinet tempered for $100+ (can't remember exactly what I paid) and I was quoted $35 for the exact same piece without the tempering...
Avrus
  • Canada
« Reply #7 on: January 31, 2008, 01:38:05 pm »
Well the price for the same glass, tempered from 'One Day Glass' is only $35.
So far the difference between temptered and non-tempered is on par with what was listed above - $20 - $30.
The cost for the glass has ranged almost 200% from the quotes I've received (500% if you count One Day Glass) so I'm not surprised you'd get different prices.
2600
« Reply #8 on: January 31, 2008, 01:49:05 pm »
There is going to be some fudge factor for different size glass, but it also depends on where you go and where you live.  I'm not a glass expert and only know about what I have been quoted and bought.
Two-bits sells the tempered to fit a Pac Cocktail for $89.  The last two pieces I had done locally were $25 and $40.  I only had regular glass quote on the last one and it was ~$20 IIRC.
Avrus
  • Canada
« Reply #9 on: January 31, 2008, 01:54:47 pm »
Well so far the lowest price is One Day Glass at $35 (shipped total $83.55), the highest is $146 and the average is around $85.  So I can get it cheaper, and considerably faster by purchasing from a Washington store, and shipping via FedEx to my house.  That really makes zero logical sense.
SithMaster
« Reply #10 on: January 31, 2008, 02:21:37 pm »
Get a quote from tommy.
Daniel B.
  • Last login:May 10, 2024, 05:08:12 pm
  • Lightgun and Point Blank enthusiast
« Reply #11 on: January 31, 2008, 05:26:11 pm »
I don't have anything constructive to tell you about your glass prices, which is a crappy situation, and I feel for you....
But back to the tempering-
Tempered glass is usually expensive as hell. I honestly don't think it is needed for a regular cab. If you are concerned about safety, you could always get some clear, or lightly tinted window tint on it. That way, if someone goes nuts and breaks it, it's not going to shatter into big dangerous chunks. The tint will keep it together, and hopefully nobody will get cut.
Tempered glass is good for taking blunt force, but force in a relatively wide area, could cause it to explode. Is that "widearea" as big as a fist? That I do not know. One thing I do know, is I'd much rather clean up normal glass than tempered glass!
(I used to be huge into fish tanks, and have drilled tons of holes, and have run into my fair share of tempered glass problems)
« Last Edit: January 31, 2008, 09:42:27 pm by Daniel B. »
Namco Exceleena II (red) | Sega Astro City (needs ms9 monitor work)
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #12 on: January 31, 2008, 06:46:39 pm »
Go with tempered (or plexi) ... how much are YOUR fingers, wrists and forearms worth ?
Avrus -- head over to CGCC and post there. There are a couple of Albertans who may be able to point you in the right direction.
http://www.cgcc.ca/forum/viewforum.php?f=9
Working: Not Enough
Projects: Too Many
Progress: None
Avrus
  • Canada
« Reply #13 on: January 31, 2008, 09:01:54 pm »
Niiice.  Thanks Cheffo.   :cheers:
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
« Reply #14 on: February 01, 2008, 04:30:25 am »
I feel your pain. Glass over here in Europe has risen over the last few years. I was told it was due to the closing of some large plants. This is probably due to China.
I would suggest going with tempered. Having smoked glass adds a fair bit of cost to it, so you could have it clear and apply some tint.
CheffoJeffo
« Reply #15 on: February 01, 2008, 06:58:31 am »
No worries -- you may have to wait a day or two -- the Western folk don't spent as much time on the board as the folks from SW Ontario.
Working: Not Enough
Projects: Too Many
Progress: None
Avrus
  • Canada
« Reply #16 on: February 01, 2008, 08:32:00 pm »
After exhausting quotes with 9 different shops I pulled the trigger with Onedayglass.  They had the best price (even after shipping) and the best delivery time.  So end of the next week I'll have a sweet piece of glass.
protokatie
« Reply #17 on: February 01, 2008, 10:13:45 pm »
Cool! What's her name?
Oh wait, you said glass...  ::)
Anyways, before going into the whole "I am going to make my own cab" I had NO idea how much simple glass cost! Its incredible! For my first cab, I will prolly forgo glass, unless it urks me too much, then I may have to spring for it... :<
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #18 on: February 02, 2008, 11:33:20 am »
i got a slightly smoked plexi glass for like $30 cut locally.
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
rdenis
  • Last login:January 11, 2011, 04:19:38 pm
« Reply #19 on: February 02, 2008, 11:44:33 am »
I used Speedy for custom cut 5mm grey tempered - 26 x 27 15/16.
Price in Kamloops, BC - $50 plus tax.  Took about 10 days as glass comes out of Vancouver.
Avrus
  • Canada
« Reply #20 on: February 02, 2008, 12:02:35 pm »
Wow that's bizarre.  Speedy's one that was in the 140+ mark.  So was Crystal Glass.
Ah well, once again ordering from the US provides the cheapest alternative.
FrizzleFried
    • Idaho Garagecade
« Reply #21 on: February 02, 2008, 01:05:05 pm »
My cocktail cab has a piece on it that is easily larger than what you are looking to order... with rounded edges... but CLEAR,  not smoked...and I paid less than $30.00 for it locally.   I am not sure if the tinting is what is making your quote so big?
Here's the glass:
Avrus
  • Canada
« Reply #22 on: February 02, 2008, 01:18:37 pm »
Here's the glass:
It's Calgary.  We're used to prices being ridiculous.  Case in point, dinner at the Cheesecake Cafe for two now runs $70 - $80.
