Author Topic: microswitch problems help! quick disconnects dont fit mag stick plus wire issue/  (Read 2332 times)
mrclean
    • Guscade
 ??? I just purchased mag-stick plus sticks, and the microswitch is "Fatter" than my current quick disconnects all my buttons were easy to swap out but now with the joy sticks they are too fat on the metal tabs what can i do ?
2,370,650 Gun.Smoke
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
E mail ultimarc they use a different size, I cant remember what it is though  ???
urbecrisch
  • Last login:February 23, 2026, 07:26:24 am
  • I was the S**T back in '82
Just go out to your local hardware store and purchase some .250 female quick disconnects.  They are bigger (fatter) than the usual .187 size.
mrclean
    • Guscade
andy from ultimarc emailed me back.. he said he sold them in 100 pack, (i tried looking on home depots web site couldnt find them) he also told me to try first using a pair of pliers to open up my existing ones.. i don' know how i'm going to do that its all tight. I bought the control panel which was pre-built i don't know anything about cutting, stripping, and crimping wires and re-connecting to the new .250 quick disconnects properly.. but looks like im going to have no choice but to learn.
2,370,650 Gun.Smoke
krutknut
  • Last login:February 08, 2012, 01:17:50 pm
Don't worry, it should be extremely easy. As long as the wires are not too short for a mistake or two...
knave
  • Last login:March 24, 2026, 03:52:12 pm
To open up the .187 female connectors first use a small screwdriver to open them up a bit then use some pliers to size them.
Hope that works.
mrclean
    • Guscade
Ooops ran out of room for the existing wires to stretch with the new disconnects, so what wire do i use it's for a "daisy chain" from a button to my joystick the wire is red. maybe ground? other wire is tiny tiny tiny and grey going from i think a mini pac looks like a ribon. But I can't seem to figure out where the red wire lead comes from reguardless I need to purchase more for the short daisy chain. ended up with 18 gauge from radio shack
« Last Edit: October 24, 2007, 05:10:47 pm by mrclean »
2,370,650 Gun.Smoke
mrclean
    • Guscade
After finally finishing It's time for game testing.. I'm finding that somethings not right in terms of game play even pacman doesnt seem to be that responsive I mean within my front end up,down, left and right work on my CP.. however my joystick is not perfectly center would that be of an importance? Also underneath I have this tiny metal piece which maybe interfering with the magnet ?
« Last Edit: October 24, 2007, 05:18:15 pm by mrclean »
2,370,650 Gun.Smoke
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
jasonbar
  • Dr. Inferno
    • The Infernolab
If I'm understanding the problem correctly, why not just file/sand/dremel/grind the tabs so they're a little skinnier to fit into the female quick disconnects?  I've done it many times.
-Jason
mrclean
    • Guscade
was i suppose to take something out ? or put something in?
2,370,650 Gun.Smoke
kowal
  • Suzo 4ever
put from base foil belt (xero)
he should better to centre to center
mrclean
    • Guscade
"um what" - geico caveman
2,370,650 Gun.Smoke
