Author Topic: Grilling in the name of...  (Read 4144 times)
merlin1310
  • Last login:July 14, 2008, 09:25:03 am
« on: October 17, 2007, 10:39:20 am »
I obtained a cheap-o cabinet from eBay and intend on MAMEing it for a Classics arcade, The cab was originally a 'Lazarian' that was converted at the factory to a 'Domino Man' and then again converted to an 'Escape From the Planet of the Robot Monsters'. Anyhow, the original CPO was stuck on there REALLLLY well and was near impossible to scrape or peel. Not having access to nuclear weapons or a blow torch, I decided to use my gas grill. I had success with it, however left in in a little too long  :banghead:. But, now I just need to sand and paint. I'll post pics when I get it looking a little better. Here is how it looked fresh off the grill.  :woot
"History admires the wise, but elevates the brave."
Re: Grilling in the name of...
« Reply #1 on: October 17, 2007, 10:52:05 am »
EFF YOU I WON'T COOK WHAT YOU TOLD ME!
Green Giant
« Reply #2 on: October 17, 2007, 11:07:02 am »
Mmmmmmmmmm... control panel with a side of fried push buttons, my favorite
Toxic Arcade, my first build
Cakemeister
  • Last login:May 31, 2024, 06:23:16 pm
« Reply #3 on: October 17, 2007, 11:35:05 am »
I guess your control panel is metal.
Seems to me that the plastic in the CPO could break down into poisonous or carcinogenic compounds when burned. Then the smoke could get into the grill and then into your food the next time you grill something. I would hose out the grill before you use it for food again.
Old, but not obsolete.
« Reply #4 on: October 17, 2007, 11:38:36 am »
Look at dude's avatar for what happens in this case.
mcfreak
  • Last login:March 01, 2021, 01:55:04 pm
  • Asteroids moving along...
    • Hobby Blog
« Reply #5 on: October 17, 2007, 11:44:21 am »
Right down the same ally of soaking it in gasoline and lighting on fire.  I think I saw that suggestion on here for metal control panels.  Sand that bad boy down and you will be good to go.
Side effect: you might have cooked off the 20 years of bacteria from all the nasty people using it!  Ewwww, 10,000 peoples dead skin roasting on an open fire...  ;D
« Last Edit: October 17, 2007, 11:46:02 am by mcfreak »
shardian
« Reply #6 on: October 17, 2007, 11:47:29 am »
ever heard of a heat gun? ::)
knave
  • Last login:March 24, 2026, 03:52:12 pm
« Reply #7 on: October 17, 2007, 11:59:01 am »
"Daddy, Why do the burgers taste like burnt plastic?"
"Shut-up and eat, it's good for you."
unclet
« Reply #8 on: October 17, 2007, 12:24:17 pm »
No joke .... clean out that BBQ well before cooking again and possibly let it run on HIGH for a while before putting food in it again.
merlin1310
« Reply #9 on: October 17, 2007, 01:30:30 pm »
Nothing dripped down there was no ooze of any kind. Basically I took the metal scraper to it (once it cooled of course) and 80% of it came right up. But, a heat gun IS a better idea. :D
I did take the "fumes" into consideration and, surprisingly, it wasn't as bad as one might think. No children will be harmed the next time I grill chicken or children.
« Reply #10 on: October 17, 2007, 01:35:57 pm »
Soot with toxic content would have gathered all over everything.  Clean the grill thoroughly.
unclet
« Reply #11 on: October 17, 2007, 01:39:03 pm »
I wonder if that super old paint had lead in it as well ..... that would be bad to digest.
bluevolume
  • Last login:July 22, 2019, 12:14:32 pm
  • I wish I'd bought more pins...
« Reply #12 on: October 17, 2007, 02:03:24 pm »
What do you use for stubborn soap scum in the bathtub?  Napalm?
SABRECADE LIVES ON
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #13 on: October 17, 2007, 03:10:26 pm »
Car dealership or detailing shops have those glass cleaning powder that you can buy.  They do work on most, but due require lots of elbow grease.
mcfreak
    • Hobby Blog
« Reply #14 on: October 17, 2007, 03:32:00 pm »
But fire is free...  :laugh2:
bluevolume
« Reply #15 on: October 17, 2007, 03:38:40 pm »
I do need to sand off a little bit on the edge of my control panel.  I'm thinking about using the wood-chipper.   :laugh2:
SABRECADE LIVES ON
gatordad
  • Trade Count: (+11)
  • Last login:Yesterday at 12:04:31 pm
« Reply #16 on: October 17, 2007, 03:55:30 pm »
:laugh2: :laugh2: :laugh2: :laugh2: :laugh2:
WareWolF
  • Last login:January 21, 2023, 02:42:16 pm
« Reply #17 on: October 17, 2007, 06:54:12 pm »
So you grill control panels, chicken, AND children!   Can I party with you, whatever you are smoking is good!
Crowquill
  • Last login:March 30, 2026, 01:03:12 pm
« Reply #18 on: October 18, 2007, 04:27:06 am »
It's not like he's alone in trying this.
Don't think I'd try it...but given enough frustration I'd definitely consider the hibachi to be a possible tool.
bluevolume
« Reply #19 on: October 18, 2007, 09:07:23 am »
Do you recommend a dry rub, or maybe some marinating?  I would try basting it with honey and adding some hickory chunks to the coals.
SABRECADE LIVES ON
« Reply #20 on: October 18, 2007, 09:17:14 am »
The hibachi would likely be safer... less surface above/next to the fire for the soot to stick on.  Can't say I would want to try and keep a charcoal fire stoked that hot for that long, though.
