Author Topic: U360: do i need the restrictor kits?  (Read 1858 times)
ARTIFACT
« on: August 06, 2007, 05:29:57 pm »
are the u360 unusable without restrictors?
i want to keep my cp versatile: switch modes on the fly, from 2/4/8/diagonals/analog/etc... thus it seems that i would limit myself installing restrictors.
is the throw too long to play fighters?
also: are the medium springs a must-have?
thanks for your input!
plus i'll save some    $$$
  • Last login:Yesterday at 05:46:43 pm
Re: U360: do i need the restrictor kits?
« Reply #1 on: August 06, 2007, 07:35:54 pm »
I like the feel of the hard spring and the round restrictor plate - it feels tighter and has a shorter throw and this seems like the dirtiest post I've ever made here.
fatfingers
  • Got UltraStiks?™
« Reply #2 on: August 06, 2007, 07:49:08 pm »
It is entirely a personal preference.  You won't know for sure until you try it both ways.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
teknomedic
  • Last login:January 05, 2011, 10:14:11 pm
« Reply #3 on: August 06, 2007, 07:52:21 pm »
On a side note.... where can I purchase restrictor plates???
ARTIFACT
« Reply #4 on: August 06, 2007, 08:32:56 pm »
divemaster127 carries all of this (member on this forum)
send him a pm and he will give you a quote.
i highly recommend doing business with him.
thx everyone - if the restrictors are not a *must* and more a personal preference, i can always order them later. I'll think about it.
fjl
  • Pixels Rule!
« Reply #5 on: August 06, 2007, 09:15:27 pm »
I got the U360's with the hard springs. I recommend the hard springs as it made the joystick movement feel a lot smoother. Didn't get the restrictor plates. Not because I don't think it needs them but because I figured I didn't need them.
The only joysticks I own are the u360's so I can't really compare them to anything. When I first tried them, the throw did kind of feel just a tad long. I've since gotten used to it. Plus used to no clicking sound and the feel of no corners like you feel when using a normal switch joystick. It is pretty much playable though. But like someone already mentioned, you can't really tell until you try it for yourself. Get the sticks, get the restrictors if you feel it neccessary. But just try it and keep whatever you feel has the better fitting.
As for me, I've gotten used the hard springs and no restrictors.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: August 07, 2007, 12:08:35 pm »
What type of games are you going to play the most?
I have the hard springs, and tried with restrictor and without.  Personally, I prefer the circle restrictor for shmups, and without for analog games, but are usable either way.  Don't play fighters, but my guess is I'd prefer a restrictor like with shmups.
Robin
Knowledge is Power
Chris G
« Reply #7 on: August 07, 2007, 12:34:47 pm »
All I can say is that they are unplayable stock.  They need restrictors and/or plates.  I'm planning to buy the springs first, see how that feels, then buy the plates if necessary.
destructor
« Reply #8 on: August 08, 2007, 02:59:39 am »
Throw is toooooooooo looooooooong to play fighters. You must have restrictors. Without restrictors you can play analog games only.
Without medium spring playing on fighters is hard. Centering is bad. This additional spring is required.
Then if you want buy U360 you must buy restrictors and spring. Without it forget about playing.
ARTIFACT
« Reply #9 on: August 08, 2007, 07:36:25 am »
OK thanks - I think I'll get springs and restrictors.
Quick questions:
are "analog games" OK with say a circle restrictor on?
(I don't want to take apart my CP after the fact. I want 1 stick for all ;D )
destructor
« Reply #10 on: August 08, 2007, 10:09:23 am »
It depends from game. Sometimes I remove restrictor for some analog games and sometimes not :) You will test it :)
ARTIFACT
« Reply #11 on: August 08, 2007, 12:02:41 pm »
OK
I don't think I'll get under there in the middle of a game, and unscrew everything just to change the restrictor though...
thanks - yes I'll order and test everything :)
