Author Topic: Tv in mame cabinet=blurryness ?  (Read 2910 times)
DcMaN
  • Last login:March 17, 2020, 06:08:08 pm
« on: July 24, 2007, 09:40:18 pm »
I recently put a 24" sanyo tv in the cabinet, and ever since windows is very blurry, it is very hard to read text. The tv has component input 480i. Right now i have it hooked up to svideo, im wondering if i change it to a component wire  if the blurryness will decrease ? Or is there something else i need to do? Games seem to look OK, however it is hard to see what game you want to play due to the text being blurry. Is there anythign i can do to fix this ?
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
Re: Tv in mame cabinet=blurryness ?
« Reply #1 on: July 24, 2007, 09:55:12 pm »
I could be wrong but any tv has pretty low resolution I had a 31" for a while and it was blurry, now I have a 60" and its very blurry, just for text though, but my 42" plasma looks supreme, I guess thats price you pay to have a real monitors resolution.
DcMaN
« Reply #2 on: July 24, 2007, 10:02:47 pm »
damn thats what i was hoping you wouldnt say :( . Think it would be worth it to use a DVI > component cable ?
Hoopz
  • Last login:April 14, 2026, 11:47:32 pm
  • Intellivision Rocks!
« Reply #3 on: July 24, 2007, 10:16:13 pm »
I have a 27 inch tv and for my purposes, it looks good.  Windows is blurry, but thats just a part of it.  I use GameEx for my front end and I can see everything quite clearly and it looks sharp.  I use a Tron theme with GameEx.
What front end are you using?  A guess would be Mame32 since you are talking about picking games from Windows.  Most of them look great but Mame32 isn't going to look good on a 24 inch tv.  You may check the wiki for different front ends if you are using Mame32.
DcMaN
« Reply #4 on: July 24, 2007, 10:19:17 pm »
ill keep that in mind, i havn't exactly set up a frond end yet, because i was debating on what to use but ill check out game ex it looks pretty cool.
Anubis_au
  • Last login:January 15, 2023, 10:12:32 pm
  • Ever danced with the Devil in the pale moonlight?
« Reply #5 on: July 24, 2007, 11:31:19 pm »
Component video would also look better than S-video. If you can output component, I'd do it.
AwesomeAlbert
  • Last login:October 28, 2014, 12:14:28 am
« Reply #6 on: July 24, 2007, 11:42:26 pm »
make your font bigger.
severdhed
  • RIP Dinosaur Hippo
« Reply #7 on: July 24, 2007, 11:48:52 pm »
TVs suck for displaying windows, it is just that way.  you'd be much better off using command line mame and a nice frontend like MALA, and avoid windows all together.
DcMaN
« Reply #8 on: July 25, 2007, 12:03:35 am »
right now, i installed game ex, and the blurryness has faded for the most part. However Is there anyway i can tell Game EX to start up as sooon as windows starts ?
tba
  • Last login:July 21, 2010, 12:27:08 am
« Reply #9 on: July 25, 2007, 12:20:36 am »
you can either just copy a link into your "startup" directory in the all programs folder, or run your FE as a shell
try http://tomspeirs.com/gameEx/Shell.htm for info on doing this.
good luck
« Reply #10 on: July 25, 2007, 05:40:34 am »
True...but they ROCK for use as a standard res arcade monitor IF they have a scart input.  That way they effectively are an arcade monitor.
Of course I mean CRT TV's...
severdhed
« Reply #11 on: July 25, 2007, 09:24:18 am »
if you want to have gameex load at startup, that is as easy as placing a shortcut in the startup folder, however people will still see that you are running windows.  if you want to completely hide windows...the wiki is very helpful
http://wiki.arcadecontrols.com/wiki/Hiding_Windows
by following these steps, you can pretty much completely disguise your system so nobody even knows it is a regular PC.  load your front end as shell and the desktop never appears at all.
i havent tried it with gameex, but it works like a charm with MALA
Jeff AMN
    • Gamer Theory
« Reply #12 on: July 25, 2007, 09:31:03 am »
Once I set Windows to 640x480, I didn't think it looked too bad at all. Sure, the icons and such were huge, but I only use Windows to launch my front end anyway. The games look spectacular on the set. I'm using a DVI --> Component adapter though.
Green Giant
« Reply #13 on: July 25, 2007, 10:32:31 am »
I found windows looks pretty crisp on my tv using component.  At first it looked terrible, but I changed the background and all the folders/font to a black-green design.  Now I can read everything without the white burning my retina.
Toxic Arcade, my first build
SirPeale
  • Green Mountain Man
« Reply #14 on: July 25, 2007, 10:56:47 am »
And of course, the lower your resolution, the better picture you'll see.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #15 on: July 25, 2007, 01:26:22 pm »
Anything higher than 640x480 is pointless on a standard TV.
NO MORE!!
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #16 on: July 25, 2007, 01:52:04 pm »
I am running svideo to a 25in rca tv and think it looks just fine.
Green Giant
« Reply #17 on: July 25, 2007, 01:54:01 pm »
It is typically impossible on a standard tv.  Hi-def can handle it.
