Main > Software Forum
If MAME does LD, is there a point to Daphne?
<< < (2/2)
Dmod:
--- Quote from: Havok on June 11, 2007, 05:00:48 pm ---For example, Daphne seems to only support keyboard encoders now. Currently there is only spotty at best support for a true joystick...
I've got Daphne working fine with my USB based Ultrastik's.  The only problem I ran into was with mouse buttons from my USB trackball.  Daphne wouldn't recognize the mouse input.
XtraSmiley:
--- Quote from: Havok on June 11, 2007, 05:00:48 pm ---Hopefully Aaron decides to use a manageable file size for the video. I don't think somewhat larger files is such a bad thing - hard drive costs have plummeted, so storage isn't as much an issue as it used to be. I would really rather have these games available via Mame - I think in the end it will be better. For example, Daphne seems to only support keyboard encoders now. Currently there is only spotty at best support for a true joystick...
I agree.  Is there a list of all LD games and a list of which ones Daphne supports anywhere?
Anubis_au:
--- Quote from: Dmod on June 11, 2007, 05:23:19 pm ---I've got Daphne working fine with my USB based Ultrastik's.  The only problem I ran into was with mouse buttons from my USB trackball.  Daphne wouldn't recognize the mouse input.
Dmod, how did you get Daphne working with your U360s?
Also, do you need mouse control within Daphne? I mean, to play the games? I thought they were all joystick controlled...
I'm like XtraSmiley, in that I'm configuring the software in my MAME pc, and I'm also mucking around with Daphne. Although, if you read the new thread I'm about to post, I'm not having much joy with the game itself. But eventually, I will be running it and playing with my U360s.
Dmod:
--- Quote from: Anubis_au on June 11, 2007, 06:02:03 pm ---Also, do you need mouse control within Daphne? I mean, to play the games? I thought they were all joystick controlled...
At the risk of hijacking this thread even further...
In my original CP setup, I was wiring my USB trackball mouse buttons to P1 buttons 1 and 2.  This worked fine for MAME but not Daphne.  I had to rewire the mouse buttons over to P1 buttons 5 and 6 instead.
I've got Daphne set up to use my P1 buttons 1 and 2 which are currently wired to my U360 through the optional wire harness that Andy sells.
Using the Daphne configuration options, I didn't have any trouble getting it to recognize the U360 button presses.
If you can't get it to work, PM me and  I can take a closer look at my Daphne setup when I get home later.
doctorhifi:
I'm interested in how you made the buttons connected to your 360s work properly with daphne.  Are you launching from a front end or just using daphne loader?
I'm launching from within a frontend (3DArcade) using command lines to skip daphneloader.  This is very nice.  BUT I can't seem to remap the buttons to work properly, however.
Can you post your dainput.ini file found within the daphne folder and also include a list of what buttons you've assigned to do what functions.
thanks
Navigation
[0] Message Index
[*] Previous page
Go to full version
