Author Topic: Can I swamp my speakers left/right?  (Read 3196 times)
« on: May 20, 2007, 10:52:13 am »
I had to mount my speakers backwards in my cabinet. The left speaker is in the right hole and the left speaker is in the right hole. Does it even matter? Is there somewhere in windows and I can reverse the sound coming out of the speakers?
polaris
  • veni vidi congai
Re: Can I swamp my speakers left/right?
« Reply #1 on: May 20, 2007, 11:02:07 am »
its not a problem , but why cant you just swap where they are plugged in?
Sensei
  • Last login:May 03, 2008, 11:30:58 am
  • Take this pebble from my hand.
« Reply #2 on: May 20, 2007, 11:16:37 am »
Depending on how you have them wired,  can you not simply wire them oppositely.  (ie swap the left and right speaker wires)?
If you've installed speakers that don't have easily disconnectable wires (and you dont wish to cut them), I don't think Windows itself has an easy way to reverse the speaker signals but some sound card drivers do.
So it depends on your sound card.
Good Luck.
(me I'd cut the wires and splice them back together... in reverse)
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
« Reply #3 on: May 20, 2007, 11:35:48 am »
I can't think of anything off hand but im sure you can download something that could do it.
17 years old and totaly addicted.
« Reply #4 on: May 20, 2007, 12:46:31 pm »
The right speaker had the volume control knob and I wanted it on the left side of the cabinet by player 1.
Herk
  • Last login:December 30, 2024, 06:58:17 pm
« Reply #5 on: May 20, 2007, 01:14:46 pm »
leapinlew,
Holy crap, I thought this would be an easy one... not so.  You could use this software http://www.actualsolution.com/ but it not freeware.  Do you have motherboard audio or add-on.  My X-fi software has a reverse stereo option.  There is no such thing in windows os, so you will have to use a software option.
Herk
PS. you could go mono for now until you find the real cure. control panel - sounds and audio devices - speaker setings, advanced - speaker setup drop down list - mono.
« Last Edit: May 20, 2007, 01:35:16 pm by Herk »
crashwg
« Reply #6 on: May 20, 2007, 02:12:08 pm »
Can you solder?  Even if you can't, it should be pretty easy to open up the speaker that contains the amp and just reverse the wires coming from the PC...  Soldering large wires like that doesn't require any experience.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #7 on: May 20, 2007, 03:44:02 pm »
If you're going to modify them, make sure you get the polarity correct, or things will sound quite odd.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
« Reply #8 on: May 20, 2007, 07:55:29 pm »
What sound card are they plugged into? Most Creative cards include a "Swap L/R Audio Channels" in their speaker setup panel.
« Reply #9 on: May 20, 2007, 10:20:55 pm »
Hell, with stable speaker wires, he could just wrap them tight and tape them down if he can't solder at all.  Worst case, wrap them nicely around the tab and hot glue the suckers.
spacies
« Reply #10 on: May 20, 2007, 10:36:19 pm »
To be perfectly honest why do you need to change them at all?!
You will hardly get stereo imaging from them being mounted where they are and so close together.
I wouldn't touch it.
« Reply #11 on: May 20, 2007, 10:46:59 pm »
I was wondering about this the most...
it sounds like what I'll do is give it a whirl and see if it sounds off. it it does, I'll either put it in mono sound, or rewire the speakers.
Thanks guys!
