Main > Software Forum
ATOMICFE 0.19 ONLINE! (see videos)
bfauska:
Mixed news on my attempts at making this work.
When I test my laptop for the scripting engine... it works, but still no AtomicFE, Same error.
However, my desktop machine does work with Atomic, and I think I like it. There are some odd things that I am not sure about. When I start the program it either lags a while or waits for a keystroke or something, whenever I try to wait it out I give up and hit Ctrl+Alt and before I can add Delete it starts to show me that it's working. I needed to play around with the configuration a little bit because after running the plug and play install I decided that I didn't want to move all my roms. The interface for setting this software up is nice. I am used to having to deal with bunches of confusing setup with some independantly-developed software and that is not the case here.
I am still going to try to fix-up my laptop and get this working, but either way I must commend you on a nice FE. I was leaning tword another popular one, but I like your setup and options better, and I haven't found any features that I would miss in your software.
Thanks, and hopefully I can get this to work on my laptop. (actually... hopefully I can get a cabinet built and get this to work on my dedicated emulation machine.)
Later,
Brian
gonzobrian:
Hey what kind of Gateway laptop do you have? I just got a CX210X. I love it. I use Atomic but have not tried it on my laptop yet, so I'll give it a go and let you know how it goes.
bfauska:
My laptop is 2 years old and in spite of being slighty worn visually it still works great. I am obviously having some trouble getting this to work with it, I can probably blame myself for that, I've put so much random stuff on this computer with very little extensive cleanup that I am sure the registry and every other little bit of the os is clogged and confused. The processor is having a bit of a tough time with games like Killer Instinct and Fighting Layer, but I get the impression that those type of games take some substantial horsepower. They run on my machine, but the audio stutters and I think that they are running slow.
Sorry for the hijack, you can have your thread back now.
Later,
Brian
Havok:
If the SP2 re-load doesn't work, Microsoft recommends doing an in-place upgrade to fix scripting engine problems:
http://support.microsoft.com/kb/315341/
Good luck!
youki:
--- Quote ---There are some odd things that I am not sure about. When I start the program it either lags a while or waits for a keystroke or something
humm..Strange, could you do that test .
Disable all plug'n play modules you installed using plugnplayManager.exe .
Open the file Atomic019.cfg with the notepad.
Find the line :
WINDOWMODE=NO change it to WINDOWMODE=YES
Save and quit
Change the color depth of your windows Desktop to 65535 color (16bit/pixel) using windows control panel, Display properties.
Run Atomic.exe
Atomic will run in a window. and may be you will see somewhere a message box, or something that could help to understand what happens. Look in the task manager what happens too. The process list... or something...
Navigation
[0] Message Index
[*] Previous page
Go to full version
