Front End Support > MaLa Frontend
MaLa Ledwiz help please!
<< < (4/5) > >>
squirrellydw:
Now that I have it working I have a couple requests for version 2 :)
1. I think it would be great if you could set all the buttons at once to a certain color.  So if I want all my buttons blue except my coin and admin buttons I just click a button and everything is set blue then I just change my other buttons to whatever.
2. Be able to change the setting from within the MaLa options so you don't have to exit out of MaLa.
3. Anyway of having it update "LIVE", so when you change something you see it right away?
4. Built in attract mode, either some already configured to run or some you can add yourself.
5. Of course the button speech.
6. What does MaLa stand for anyhow??
Just some suggestions, I am sure not all can or will be done.  Just want to thank you all for such great work.  I am glad I tried MaLa out and that you have the LEDWiz plugin.
Sorry for not understanding how the plugin directory was supposed to work.
loadman:
--- Quote from: squirrellydw on January 21, 2007, 11:19:04 am ---Now that I have it working I have a couple requests for version 2 :)
HI..  :D
Great News. I have added the error message to V2. This will avoid directory issues for future users.
Background:
At the moment EDGE is coding the Config Maker (Led-Wizard) and I hold the actual Led-Wiz Plug-in code (that reads the config file) and have added little things for V2 since Master Swindus created it.
--- Quote ---1. I think it would be great if you could set all the buttons at once to a certain color.  So if I want all my buttons blue except my coin and admin buttons I just click a button and everything is set blue then I just change my other buttons to whatever.
Edge to respond to this one.
--- Quote ---2. Be able to change the setting from within the MaLa options so you don't have to exit out of MaLa.
Sorry. A downfall of the Plug-In system as the settings are read on MaLa start. FYI with MaLa hardware you can adjust within MaLa itself (I use that)
Maybe Edge could have a demo in his Set-up prog to show you how it will look before you start MaLa?
--- Quote ---3. Anyway of having it update "LIVE", so when you change something you see it right away?
Edge to respsond to this one
--- Quote ---4. Built in attract mode, either some already configured to run or some you can add yourself.
This is happening for V2 already ;)
--- Quote ---5. Of course the button speech.
I want this to happen too~~  ;)  Still working on it. The speech is easy. The options to skip etc are causing me work
--- Quote ---6. What does MaLa stand for anyhow??
I think the Website tells you
MAame (and more) LAuncher
Thanks for the feedback
Have Fun
squirrellydw:
OK sounds good.  Hope Edge can do some of the requests.  Thanks
edge:
--- Quote from: squirrellydw on January 21, 2007, 05:12:49 pm ---OK sounds good.  Hope Edge can do some of the requests.  Thanks
Glad you got it working, squirrelly...
As loadman said, version 2 is in the works, so adding these should be doable.... I like the idea of a LIVE test.  I will check these out this week and report back.
squirrellydw:
cool, if you need me to test anything I will be happy to.  I have two LEDWiz but I can only test one at a time right now.  Next month I will have three and should be able to use all of them when I get my computer installed, near the end of February
UPDATE!!  I bought a USB hub so I can test both now  :applaud:  I needed one anyhow, I am going to have like 10 USB devises in my cocktail table.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
