Front End Support > MaLa Frontend
MaLa Ledwiz help please!
<< < (3/5) > >>
edge:
hi squirrelly...
Your ledwiz settings should be saved as ledwiz.cfg (not .txt)... and saved in the same directory as your mala ledwiz plugin.  Is that the way you have it?
loadman:
--- Quote from: edge on January 20, 2007, 11:50:11 pm ---hi squirrelly...
Yeah Good point.  Even if that is not squirrelly's problem I should add an error message if the cfg.file is not found where it is supposed to be don't you think? I will look at that
edge:
good idea.  we can never have enough error checking.. heh...
loadman:
I just did a test
And sure enough you seem to be on the money Edge
If the cfg file is not at expected location nothing happens, I just tested it.
I will add an error message.
squirrellydw if you don't have any luck I can e-mail you a special version of the plug-in that will have an error message that will indicate where it is looking for the cfg file (if not found).  It also does a short random led sequence when you launch mala to prove you Ledwiz(s) are working and the Plug-in is talking to it.
Good Luck and have fun
squirrellydw:
Yeah, it is named ledwiz.cfg and it is in the mala ledwiz plugin directory.  I only renamed it .txt to upload it.
UPDATE!!!   :applaud:
I have it working now, I moved the ledwiz.cfg file into the plugin folder and not the MaLa LEDWiz Plugin v1.0 folder.  I think I was miss understanding what you said above
This is where I had it
C:\Downloads\MaLa v1.0 RC8\plugins\MaLa LEDWiz Plugin v1.0
and this is where it is now
I think the problem was that I had everything in a folder with in the plugins folder.  Now I have the .cfg file and the .exe file right in the plugins folder and NOT the MaLa LEDWiz plugin v1.0 folder.
loadman, you can ignore the PM I sent you
thanks for the help, you guys rock  :cheers:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
