Author Topic: MDF or plywood to support 27" monitor??  (Read 2002 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: January 02, 2007, 11:24:51 pm »
I am almost ready to make the top for my 27" cocktail table.  I am going to cut 2x4s and mount them to the top for proper spacing and support.  My question is what is better or stronger to use, 3/4 MDF or 3/4 plywood?  I will be gluing a 1/4" sheet to the top for a total of 1" but the 1/4 isn't really going to support anything.
I b**ch. People listen!!
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
Re: MDF or plywood to support 27" monitor??
« Reply #1 on: January 03, 2007, 08:57:31 am »
I would vote for the Plywood but do not have any data to support my claim.
MDF just seems to warp over time when holding up heavy stuff like monitors.
arzoo
  • Last login:March 24, 2026, 08:14:12 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #2 on: January 03, 2007, 09:11:34 am »
Either will work fine as long as the shelf is well supported. But I'd go with the ply because it's lighter.
Robots will kill you.
Arcade Addiction
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
« Reply #3 on: January 03, 2007, 10:33:29 am »
Ply will also be more structurally sound
Xam
Can't talk to a psycho like a normal human being.
  • Last login:April 18, 2026, 05:46:43 pm
« Reply #4 on: January 03, 2007, 11:45:09 am »
I'd also go with the plywood.
squirrellydw
« Reply #5 on: January 04, 2007, 04:20:34 pm »
thanks, I will go with some nice oak plywood
shardian
« Reply #6 on: January 04, 2007, 04:24:41 pm »
if you are worried, use some l-brackets like the ones used to put shelves on walls. You could also reinforce the shelf with some 2x4's running the length.
MPTech
  • Last login:April 03, 2026, 12:50:29 pm
  • UltimateArcade completed!
« Reply #7 on: January 04, 2007, 06:29:22 pm »
I'd also go with plywood, but oak isn't necessary, just more costly and heavier.  Unless it is seen and you plan to stain it, oak is overkill.
MPTech
   Better living thru technology!   ;-)
somunny
  • Is it hot in here?
« Reply #8 on: January 04, 2007, 07:39:29 pm »
I used mdf supported by a couple of 2x4's.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #9 on: January 04, 2007, 09:04:12 pm »
likewise...but this is for a cocktail...i'm assuming yours is an upright...?
squirrellydw
« Reply #10 on: January 04, 2007, 09:32:12 pm »
I will be supporting mine with 2x4s also
somunny
« Reply #11 on: January 04, 2007, 09:37:20 pm »
Read that wrong.  Thought he was talking about supporting the bottom.  Carry on.
daywane
  • GRRRR!
« Reply #12 on: January 05, 2007, 11:24:54 pm »
I just used 2x4's
I had a bunch to use. and was free.
I also added a shelf to my PC desk with MDF. I have had two 19 inch PC monitors on it for close to a year now. now problems yet
