Author Topic: pc problems need help ( beeeep,BEEEP ) "fixed"  (Read 2426 times)
daywane
  • GRRRR!
« on: January 02, 2007, 07:15:13 pm »
every thing is working fine
gateway
1.8 CPU
256 meg ram
had a not so legal xp pro on it
I found the original restore disks so I put the correct XP home on it
Updated all the drivers and service PAC 2
now ever 5 or 10 min. I hear a low pitch beep and a higher pitch beep
maybe like 5 seconds each
CPU fan going?
memory checks out, OK
I removed all cards, AGP and PCI
reseated memory cards
reseated the CPU fan
no luck still beeps.  :dunno
never did this till I put xp home on it.
PC belonged to MY sister. (bought from gateway new)
after a few years she got a nasty virus.
She got fed up with it and gave it to me.
I formated it and stuck in XP Pro SP2
never had it on the internet.
The other day I thought I would give this PC a try on the web.
She had the restore disks.
( she said they did not work)
I had no problems at all with them
I went to my father in laws house (high speed internet there)
did like 2 hours of updating
and seems great but now the stupid beeps.
« Last Edit: January 06, 2007, 11:06:12 am by daywane »
Loki
  • Last login:August 14, 2012, 08:00:32 am
    • Deathnote
Re: pc problems need help ( beeeep,BEEEP )
« Reply #1 on: January 02, 2007, 07:29:53 pm »
And you get what... beeping and all black screen?
Does it stop somewhere?
You can often find the meaning of the beeps in the mainboard manual and maybe on internet.
Don't eat yellow snow.
daywane
  • GRRRR!
« Reply #2 on: January 02, 2007, 07:33:48 pm »
no problems with pc
as beeps come and go there is no noticable effect.
dvd copies
game play
as I type to you a set of beeps
the PC shows no problems
Loki
    • Deathnote
« Reply #3 on: January 02, 2007, 07:51:14 pm »
Ah, so it's a windows thing... didn't read right, I'm a bit tired :P
I found some topic that sounds like a similar problem
http://forums.techguy.org/windows-nt-2000-xp/523530-windows-xp-beeping.html
I hope you can find something useful in it.
btw, does it come out of your normal pc speakers or the little one inside your pc.
« Last Edit: January 02, 2007, 07:53:59 pm by Loki »
daywane
  • GRRRR!
« Reply #4 on: January 02, 2007, 08:18:23 pm »
internal speaker
I will check out your link
on google all I can find is a boot problem
I do not have anything like that.
starting to think a bad driver
I did change modems after installing gateways aps (fax and what not)
also I changed keyboards.
jace055
  • Last login:August 22, 2025, 09:32:12 pm
« Reply #5 on: January 02, 2007, 08:51:44 pm »
1)  Check the power management settings in windows and in bios to make sure you don't have it set to laptop or something.  I think this is more of a bios problem because windows notification would come out of the sound card.
Boot into windows and play a game for a few minutes to get the processor temp up the exit out of the game and reboot into BIOS and check your processor temps.  What motherboard/gateway model number are you running?
2)  Unplug the internal speaker.  That will fix it for sure.
daywane
  • GRRRR!
« Reply #6 on: January 02, 2007, 09:06:28 pm »
I removed the old modem crap
and the keyboard crap still waiting for a beep
I am starting to think problem has been solved.
to be honest I never knew of windows beeps. I thought all beeps were the bios telling me somthing is bad wrong.
first time I have run into a windows beep
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
« Reply #7 on: January 02, 2007, 10:54:59 pm »
Could always just reformat and try again and see if it comes back...
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« Reply #8 on: January 03, 2007, 08:55:33 am »
If all else is working fine, I'd unplug the speaker.
If it's one of them little surface mount jobs, then put a piece of tape over the hole.
I'd bet it's a keyboard or other input buffer error. Maybe you control interface is triggering it?
SirPeale
  • Green Mountain Man
« Reply #9 on: January 03, 2007, 08:50:34 pm »
I betcha it's the stickykeys things going on.
If you hit the control or shift keys five times in a row, it turns this feature on.  I think it makes this sound.
Chaos
  • Last login:July 18, 2007, 05:44:58 pm
  • Next Year
« Reply #10 on: January 04, 2007, 08:03:37 am »
This may sound stupid but on my Dell server box I had the covers off and it would beep. I don't run covers on any other box but this one gave me fits.
My first time in the spotlight was from a Helicopter
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #11 on: January 04, 2007, 11:10:03 am »
could it be a stuck key on a keyboard.  or a motherboard problem.  theres not too much windows would send threw the system speaker.
« Reply #12 on: January 04, 2007, 12:25:44 pm »
My gateway beeped all the time. I put in a different computer.
It seemed to beep when multiple things were going on. I turned off all the accessibility stuff. I was using an IPAC on the PS2 port.
daywane
  • GRRRR!
Re: pc problems need help ( beeeep,BEEEP ) ( fixed)
« Reply #13 on: January 06, 2007, 12:26:53 am »
it was eather this or the driver for the cey bprd I am no longer working with.
eather way problem is gone. Thanks
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
« Reply #14 on: January 06, 2007, 10:20:31 pm »
:laugh2:  Looks like you are having a problem typing without it...J/K
Havok
  • Trade Count: (+17)
« Reply #15 on: January 06, 2007, 10:39:54 pm »
Daywane - stop drinking before typing: you are supposed to do that after!
