Author Topic: How do you clean Metal Contacts?  (Read 4685 times)
Gavica
  • Last login:March 05, 2011, 09:56:15 am
« on: December 12, 2006, 01:31:46 pm »
For example I have this old 32X, and the contacts are becoming quite rusty, is there a way to clean them???
Re: How do you clean Metal Contacts?
« Reply #1 on: December 12, 2006, 01:37:01 pm »
Alcohol.  If that doesn't work, light sandpaper.
shardian
« Reply #2 on: December 12, 2006, 01:43:41 pm »
Alcohol brought many Nintendo and Sega Genesis games back to life in my day.
quarterback
« Reply #3 on: December 12, 2006, 01:47:04 pm »
Interestingly enough, alcohol has also brought ME back to life in my day  :cheers:
-- Chad Tower
shardian
« Reply #4 on: December 12, 2006, 01:56:08 pm »
hehe...not the alcohol we are talking about...unless you consider fatal diahhrea a good life. :laugh2: :laugh2:
Gavica
« Reply #5 on: December 12, 2006, 02:07:08 pm »
how do I apply the alchohol?
« Reply #6 on: December 12, 2006, 02:18:36 pm »
you can apply the alcohol with a Q-tip.  Another method that has seemed to work for people is (gently) rubbing the contacts with a pink eraser on the end of a pencil.
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« Reply #7 on: December 12, 2006, 02:36:27 pm »
Theres some stuff I used to use which is basically Electrician's contact cleaner.
« Reply #8 on: December 12, 2006, 02:49:22 pm »
With ice and a mixer of your choice.
shardian
« Reply #9 on: December 12, 2006, 03:23:47 pm »
Since those are the large contacts, I would use a tissue to clean them real well. It should work just fine then, but if not then use a very light grade sandpaper. I'm not sure how thick those contacts are and you don't want to damage them.
« Reply #10 on: December 12, 2006, 03:28:19 pm »
They're pretty thick and IIRC not plated.  He could use the sidewalk and they'd survive.  No need to be gentle at all.
Gavica
« Reply #11 on: December 12, 2006, 03:47:13 pm »
I have sand paper, is there a posibility of damaging it? want to make sure before using it, it caming in a kit for painting scale planes.
« Reply #12 on: December 12, 2006, 04:34:18 pm »
Need the grit rating to tell you that.
