Author Topic: MAME 0.109 is out!  (Read 5658 times)
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
MAME 0.109 is out!
« on: September 26, 2006, 01:14:43 pm »
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re: MAME 0.109 is out!
« Reply #1 on: September 26, 2006, 01:21:22 pm »
Has anything changed in the past 10 releases or so that would require me to upgrade my CPU from an Athlon XP 1800+?
mrclean
    • Guscade
« Reply #2 on: September 26, 2006, 01:49:21 pm »
I hope that new "Track ball" games will soon be on the rise and that new rom's will pop up. Such as bowling games, and golf etc..  :cheers:
2,370,650 Gun.Smoke
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« Reply #3 on: September 26, 2006, 07:04:50 pm »
Yes a list of upgrade details would be beneficial. New games, improvements etc please
johnm160
  • Last login:April 09, 2024, 09:00:46 pm
« Reply #4 on: September 26, 2006, 07:33:35 pm »
Ok this is from the whats new.txt
 added external coin counters and coin lockouts
So now you can wire counters??
krick
  • Gotta have blue hair.
« Reply #5 on: September 27, 2006, 02:59:13 am »
Is that sarcasm?  If not, apparently, you haven't heard the screams of a thousand mame users crying out in terror when Aaron rewrote the renderer/artwork system in MAME 107.
As usual, the CPU specs have been climbing.  However with the renderer re-write, MAME now requires a somewhat modern video card now.  Something at least DirectX 8.1 compliant, I imagine, and 64MB of onboard memory is probably a good idea if you plan on running any of the new ultra high res artwork that the new system requires.
There's some experimental multi-threading going on in the new renderer that can be turned on in 108 with an ini setting.  It's just the renderer, not the game code that is multi-threaded so don't get your hopes up.  It will only make a difference in certain borderline cases that are limited by the renderer.
Word on the street is that Intel Conroe (Core Duo) CPUs are the new speed champions for MAME.  Plus, some of the low end models are VERY overclockable.  At stock speeds, the Conroe chips are beating AMD chips, and overclocked, they're wiping the floor with their dead bodies.
Obviously, games that ran at 13 frames per second before are not going to be playable on anthing any time soon, including an overclocked Conroe.  But the situation is certainly much improved.
« Last Edit: September 27, 2006, 11:28:31 am by krick »
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
wolfi
  • Last login:April 14, 2026, 03:57:25 am
« Reply #6 on: September 27, 2006, 03:04:37 am »
External coin counters are shown in the ui under bookkeeping, for games that support this. If the coin counter bit is documented in the driver, you could take this bit, route it to an output, write an external application that takes this bit and connect a real external counter.
Mick
  • Last login:October 28, 2006, 12:32:20 pm
« Reply #7 on: September 27, 2006, 07:05:14 am »
Yeah, when do Golden Tee Fore! get out ? Can't wait for that to happen !
Marky_1979
    • Personal Webspace
« Reply #8 on: September 27, 2006, 08:48:32 am »
Wow yes Golden tee is amazing what versions are currently playable?
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« Reply #9 on: September 27, 2006, 09:08:02 am »
I doubt that I'll ever get my coin counter wired up. The last guy did a real hatchet job on the wiring when he stripped my cab. At least I got the lights working again.
Make your cabinet look its best with custom art from
Gamecreature!
johnm160
« Reply #10 on: September 27, 2006, 09:12:17 am »
Yeah, I hate to leave perfectly good coin counter doing nothing in the bottom of my case.....but writing an external app is not for me  :o
It is probably better not to know how much I play anyway
screaming
  • Registered lUser
« Reply #11 on: September 27, 2006, 10:09:43 am »
  Heh :) No, it wasn't sarcasm.  I've been out of the game for a while, so I appreciate the summary!  Thanks :)
jcroach
  • Last login:March 31, 2026, 12:26:11 pm
« Reply #12 on: September 27, 2006, 12:04:43 pm »
Any idea if the [Num lock] [caps lock] LED issue that arose in version 0.105 has been fixed in this release?  Or am I behind the game and it's already been fixed?
krick
« Reply #13 on: September 27, 2006, 12:13:40 pm »
In 108, I think, there was a big change and a new output system was created.  MAME now sends windows events for things like LEDs and you need to run an external app that listens for them and does the job.
Read more about it here...   http://aarongiles.com/?p=181
Hantarex Polo 15KHz
jcroach
« Reply #14 on: September 27, 2006, 12:36:53 pm »
Thanks!  I'll work on getting ledutil.exe to work.  Any advice?
  • Last login:March 28, 2026, 02:54:37 pm
« Reply #15 on: September 27, 2006, 06:29:00 pm »
 Not really... it works EXACTLY the same as the old led system that was built into mame.
just remember that the ledmode flags that used to be in your mame.ini now have to bet set via command-line when you launch ledutil
jcroach
« Reply #16 on: September 28, 2006, 08:27:50 am »
I couldn't find a list of the command-line options in any of the help documents.  Do you know where I can find a list?
