Main > Woodworking
fix coin door cutout problem...
Pages: << < (4/6) > >>
NiteWalker:
It's just that feeling of *knowing* that you have your cabinet put together with construction paper (or at least the coin door ;)). I think it's every cabinet builder's dream that when humans become extinct via meteor or whatever their arcade machine is the only thing left standing.  ;D
The next ark should be an arcade cabinet :applaud:
@stew_bidasso
Don't know if filler or real wood will remedy this...
use 1/2" steel! :police:
NightGod:
Lol-not saying I'd use construction paper, just saying that filler or bondo is more than enough for a purely cosmetic fix =p
ChadTower:
By the time he cut four corner pieces and got them in place he could have cut a whole new front piece.
NiteWalker:
True, but it would be a problem if he already had the coin door panel glued and screwed in place before noticing the problem. Also, he may not have had enough material left for a new panel.
ChadTower:
Yep.  Hopefully he has learned to measure at least twice before making any cuts.  I learned that the hard way too.
Go to full version
