Main > Woodworking
fix coin door cutout problem...
Pages: << < (6/6)
leapinlew:
Replacing the sheet of wood the coin door sat in not an option? Usually the coin door area isn't that large.
Sounds like you went the repair route already, but I might've considered cutting a new front plate for the arcade.
melarky:
I had considered replacing the front piece, but thought that the putty solution sounded easier and faster.  Now that it's been such a pain, I probably should have just done that (oh well, lesson learned).  I will probably try to sand this tonight, and then apply the finall putty to smooth it out (not the big chunk of putty I was using before).  Hopefully that will be the end of it :)
melarky:
I finally finished this project, and you can't really tell that there was ever a problem with the coin door.  I have posted details and pics:
http://forum.arcadecontrols.com/index.php?topic=60545.0
Thanks for all of your help.
Pages: << < (6/6)
Go to full version
