Author Topic: 5.25 drive cage thingy  (Read 3942 times)
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
« on: September 18, 2006, 04:20:14 pm »
all i need is a cage going from top to bottom, DVD drive 5.25", a 5.25" bay empty, then a 3.5"drive bay for a hard drive.
thats all i need is a cage but ebay and maplins don't seem to do that!
it just needs to be able to screw on to a bit of board with holes in it for the bays to poke through.
incase your wondering i want it because it does not only make life easier but looks smart haveing it neatly in the bottom of my arcade cab incase i need to load more things on in future.
BobA
  • What Me Worry?
Re: 5.25 drive cage thingy
« Reply #1 on: September 18, 2006, 05:10:15 pm »
Rip one out of an old computer.   Get the old computer from someone who is throwing it out or pick one up at goodwill or the like for a few dollars.
AtomSmasher
    • Atomic-Train
« Reply #2 on: September 18, 2006, 05:21:03 pm »
Heh, at first I thought you were doing a parody of "the jerk".  I agree, salvage one from an old computer case.
And that's it and that's the only thing I need, is this. I don't need this or this. Just this ashtray. And this paddle game, the ashtray and the paddle game and that's all I need. And this remote control. The ashtray, the paddle game, and the remote control, and that's all I need. And these matches. The ashtray, and these matches, and the remote control and the paddle ball. And this lamp. The ashtray, this paddle game and the remote control and the lamp and that's all I need. And that's all I need too. I don't need one other thing, not one - I need this. The paddle game, and the chair, and the remote control, and the matches, for sure. And this. And that's all I need. The ashtray, the remote control, the paddle game, this magazine and the chair.
Flip_Willie
  • Last login:November 02, 2020, 11:20:46 pm
    • FlipWillie's Site
« Reply #3 on: September 18, 2006, 05:32:10 pm »
     My opinion goes along with the rest, just use an old atx case.
     I actually found an old atx case in my neighbors trash, and it turned out very well ( After I hacked it up quite a bit ).
     On a side note, some hard drive bays are designed to be removable which makes them very easy to mount in a cabinet.  On the other hand, I haven't seen a case that has a removable 5.25" bay (In my situation I am not using a DVD or CD-Rom Drive, just USB, so it wasn't an issue ).
NightGod
« Reply #4 on: September 18, 2006, 09:30:11 pm »
And my dog. *GRRRRRR* OK, maybe not my dog.
The other popular option seems to be pipe strapping-I keep forgetting to pick it up, going to have to now that I have the CP mounted on the cabinet and can't put off sticking in the computer because I kept playing at the table :laugh2:
Chris
    • Chris's MAME Cabinet
« Reply #5 on: September 18, 2006, 10:19:21 pm »
I mounted a 5-1/4" drive cge to the top of the coin box... fits perfect and makes the drives accessible behind the coin door.
--Chris
jfh2112
  • Last login:November 27, 2010, 01:27:12 pm
« Reply #6 on: September 18, 2006, 11:00:48 pm »
We have an external USB DVD-RW drive at work, and the drive is mounted in its box with small L-brackets. That might be another option.
david656
  • Big Man!
« Reply #7 on: September 19, 2006, 02:44:54 am »
that cage is exactly what i want but not behind a coin mech as mine isnt situated like that
how did you get that
NightGod
« Reply #8 on: September 19, 2006, 03:46:21 am »
Looks like he cut/took it out of a tower PC case.
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« Reply #9 on: September 19, 2006, 07:47:09 am »
So your drives are accessable from outside the cabnet? Cool.
Got a picture of the front side?
Chris
« Reply #10 on: September 19, 2006, 08:21:42 am »
Ripped.  It was riveted in, so it took some leverage from a big screwdriver and brute force from two guys to tear it out.  The 3.5" drive cage came out easier; it's screwed to the left wall holding the main hard drive (the one in the 5.25" cage in that pic is temporary.)
Not just drives.  That floppy drive at the top is mounted in a 5.25" sled that also has USB ports mounted in it.  I'll get a pic of it when I get home.
--Chris
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #11 on: September 19, 2006, 09:45:23 am »
Erector Set.
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #12 on: September 19, 2006, 09:45:36 am »
I fashioned something similar for another member of this board which was crafted from an old AT case and the trusty dremel tool.
He also wanted a place to mount his PS Supply so it ended up being a drive cage combined with a place to mount PS.
I haven't had a reason to do a similar hack job of late but have lots of old cases lying around.
If you can't get your hands on something local I could probably hack one up for cost of shipping. Send PM if needed.
Extreme8
  • Last login:August 24, 2008, 03:46:24 pm
« Reply #13 on: September 19, 2006, 11:53:36 am »
Exactly what I did with mine.
If you don't want to mess with prying the thing out of the case just drill out the rivets. Quicker, you don't bend the cage, and doesn't require a trip to the emergency room to get stitched back up.
krick
  • Gotta have blue hair.
« Reply #14 on: September 20, 2006, 01:20:55 am »
Consider *not* mounting your computer parts to the floor of your cabinet.  It's far too easy to drop something on it and damage it.  Also, consider what might happen if you accidentally dropped something metal like a screwdriver or a token onto your motherboard while it was running and it landed just right (or wrong as the case may be)....  POOF!
Finally, think about what would happen if there were a flood of some kind.  There's a reason that arcade cabinets have the boards mounted to the inside wall of the cabinet.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
krick
« Reply #15 on: September 20, 2006, 01:24:42 am »
Oh, and if you have more than one hard drive (it only fits 3.5 inch drives), these are pretty nifty for keeping them cool.  And if you mount it in the right spot, the fan can also help cool your CPU or video card.
http://www.newegg.com/Product/Product.asp?Item=N82E16811999141
Hantarex Polo 15KHz
david656
  • Big Man!
« Reply #16 on: September 21, 2006, 02:02:30 am »
the look wicked i will definatley look into it
Chris
« Reply #17 on: September 21, 2006, 10:51:31 am »
Here it is.. took it with my phone so it's not a great pic...
--Chris
_) (V) (-)
« Reply #18 on: September 21, 2006, 11:51:56 am »
That is a slick idea Chris, it also makes the coin door serve a useful function.
(Mine was just going to be ornimental)
