Author Topic: LED lighting options?  (Read 2776 times)
Darq
  • Last login:May 01, 2012, 10:30:55 pm
  • Darq Control
« on: August 27, 2006, 03:27:18 pm »
I've done the standard searching and reading but wanted some clarification.  I'm planning on building a CP with joystick, 7 game buttons and 1 player button for players 1 and 2.  This effectively leaves me with 8 LEDs per player (9 if I get a lighted joystick).  I wanted to go with RGB but as far as I can tell there is nothing out there that will support (3 x 8) x 2 = 48 outs.  I read this was a possible to do with the LEDwiz but probably a far off future item.  Other than grouping LEDs or cutting down colors do I have any other options for animated LEDs in game Mame?
Feel free to tell me if I'm and idiot and over looked something obvious.
MYX
    • MYX Digital Blog
Re: LED lighting options?
« Reply #1 on: August 27, 2006, 05:07:51 pm »
RGB will eat your channels quickly. You have the option of running more than 1 LEDWiz at a time and I believe that it is MALA that is currently in development of a more intensive user platform for the Wizs. BUT!, you have to purchase a set of replacement chips to do so.
I chose to use RGBs on the main buttons and single colors on the rest. Remember that not all games used that many buttons. So, if you hit the main jump / fire buttons and made the rest a single color you can make it work.
BTW, remember that for every color you add, you have just added a wire and resistor. The wires build up quickly. Eventually you look down and say, crap, that is several hundred feet of wire sitting there.
I chose PowerMAME through MAMEWah, but am running up against a wall with it right now. I can not make the attract mode work with MW. It will work with PM32. Also the buttons lit durring the game seems to be un usable right now too. But I am still working on this.
M    Y    X
Darq
  • Darq Control
« Reply #2 on: August 27, 2006, 05:37:31 pm »
I thought that you "could" use 2 LEDwizs but they wouldnt be in sync
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #3 on: August 27, 2006, 07:08:30 pm »
FYI MaLa works right now (not development)   ;)
* Either with a LedWiz (replace one chip) for basic support see Here
* Or Mala Hardware see here
Some MaLa Screens for LEDS and LCD:
« Last Edit: August 28, 2006, 07:39:29 pm by loadman »
RandyT
  • Last login:April 16, 2026, 01:13:33 pm
    • GroovyGameGear.com
« Reply #4 on: August 27, 2006, 10:56:45 pm »
Also keep in mind that if you go this route, you are essentially crippling the LED-Wiz by removing the PWM (48 brightness levels) and hardware pulse FX.  This means only 7 colors are possible with RGB LEDs using the replacements chip instead of the LED-Wiz's normal 110,592.
Just thought this needed to be brought up in case that kind of thing is important to anyone ;)
RandyT
MYX
    • MYX Digital Blog
« Reply #5 on: August 28, 2006, 08:39:57 am »
I was not saying it was a good idea, I was just offering a suggestion.  :P
M    Y    X
loadman
    • MaLa
« Reply #6 on: August 28, 2006, 04:48:54 pm »
And a valid one too.
Randy T is just pointing out that if you want lots of colours/brightness levels this is not an option for you.
However it is completely reversable (if you want) have a read of my post   ;)
http://forum.arcadecontrols.com/index.php?topic=55856.msg551834#msg551834
« Last Edit: August 28, 2006, 04:52:16 pm by loadman »
MYX
    • MYX Digital Blog
« Reply #7 on: August 28, 2006, 05:06:23 pm »
In my reading today, I ran across Atomic FE (was recomended by Havok). Youki is working towards LEDWiz capibilities. Don't know what it will do just yet, but just thought I would mention it. Personally I would really rather use the stuff from Randy I bought and not have to purchase a different set of chips. The LEDWiz Opperates beautifully under PM32. I made up a slew of LWA's and made an LSQ to string them all together. It was like a pinball machine.
M    Y    X
Darq
  • Darq Control
« Reply #8 on: August 28, 2006, 05:11:10 pm »
Are we going to see a LEDwiz that can handle more than 32 LED channels?
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #9 on: August 28, 2006, 05:43:17 pm »
You can use up to 16 LedWiz's i think, so that is considerably more than 32 channels.
Quote from: saint
saint is all powerful.
Apparently he is.
loadman
    • MaLa
« Reply #10 on: August 28, 2006, 07:44:57 pm »
I'm interested to see when and what level Youki will support.
FYI
I have 2x MaLa Hardware and 2x LedWiz.  I love my LEDS!!!!!    :(
My Wife does not understand   ;)
Darq
  • Darq Control
« Reply #11 on: August 28, 2006, 08:47:43 pm »
I didnt think multiple LEDwizes was supported yet
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #12 on: August 28, 2006, 09:37:01 pm »
I have a question slightly off topic.  There are 4 wires on the RGB Drive, does it matter what wire goes where?  I assume one wire goes to the +5v and the other three connect to the LEDWIZ, I am just not sure if certain wires have to connect to a certain place.
I b**ch. People listen!!
RandyT
« Reply #13 on: August 28, 2006, 10:07:09 pm »
They are if you are using PowerMAME or the latest OCX from GGG.  Up to 16 LED-Wiz boards for a total of up to 512 outputs.
The red marked wire goes to +5.  The other three, starting with the first wire after the red marked one, are Blue, Green and Red.  I would recommend picking a group of three outputs and wire them in the standard RGB order, using the lowest number in the group as Red and the highest number as Blue.
RandyT
squirrellydw
« Reply #14 on: August 29, 2006, 12:34:35 am »
RandyT
Thanks Randy, however I am a little confused by what you mean " I would recommend picking a group of three outputs and wire them in the standard RGB order, using the lowest number in the group as Red and the highest number as Blue."
loadman
    • MaLa
« Reply #15 on: August 29, 2006, 12:55:41 am »
I believe he means for example
Wiz Output 1- Red (LED 1)
Wiz Output 2- Green (LED 1)
Wiz Output 3- Blue (LED 1)
Wiz Output 4- Red (LED 2)
Wiz Output 5- Green (LED 2)
Wiz Output 6- Blue (LED 2)
Wiz Output 7- Red (LED 3)
Wiz Output 8- Green (LED 3)
Wiz Output 9- Blue (LED 3)
..etc
Probably easier to configure that way
squirrellydw
« Reply #16 on: August 29, 2006, 07:26:29 am »
ok, thats what I was going to do.
Thanks, you guys rock
MYX
    • MYX Digital Blog
« Reply #17 on: August 29, 2006, 07:32:11 am »
I actually made the wires corrospond to the color for easier troublshooting later in life.
M    Y    X
squirrellydw
« Reply #18 on: August 29, 2006, 08:15:25 am »
The ones I got already have the wire attached, 28g I think.  However I have to make them longer so I might do the same and attach 22g wire to the 28g wire.
MYX
    • MYX Digital Blog
« Reply #19 on: August 29, 2006, 10:23:18 am »
Yeah, I did not want to be hindered by my +5 line. Since it is a ribbon, it travels all the way back to the board. I branched the +5v at each LED button pod.
M    Y    X
JohnnyB
  • Newbie
  • Last login:August 29, 2006, 11:00:11 am
« Reply #20 on: August 29, 2006, 11:00:11 am »
I've working with LED Supply for several LED projects.(www.LEDSupply.com)...Maybe they can help?
loadman
    • MaLa
« Reply #21 on: September 02, 2006, 06:54:56 am »
Just in case you have not been following the software threads
have a look
http://forum.arcadecontrols.com/index.php?topic=55856.msg562479#msg562479
