Author Topic: Do you need a frontend with MAME32  (Read 4083 times)
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« on: April 29, 2006, 10:26:45 pm »
I plan on using mame32 for my cab and was wondering does it use a frontend?  thanks
Its easy to like someone,
If you dont know them very well.
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
Re: Do you need a frontend with MAME32
« Reply #1 on: April 29, 2006, 11:18:14 pm »
Mame32 IS mame with and inbuilt frontend. It's also crap for running in a cab.
Brad
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #2 on: April 30, 2006, 05:58:26 am »
Mame 32 is cool for running from a pc. And it is easy to set up so it is great for beginers. It is not that great in a cab if you want to hide windows
You can get another Fe's to launch mame 32 (if you want) but the majority of users here would agree that it takes a few more resources and you would be better of with command line mame launched from a fe in a cab (especially if it is an old pc)
kiddk1
  • HAP KI DO
« Reply #3 on: April 30, 2006, 09:32:34 am »
I am new to this and have never run mame from command line, is it complicated?  do I have to type in a command line each time I want to play a different game?
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
« Reply #4 on: April 30, 2006, 02:46:00 pm »
I curently use mame32 on my cab and its fine because I mapped all of my controls so I can get around in windows with a joystick and my button. I donbt have any admin buttons tho so I cant get out of games without the keyboard.  My player1 start button is enter and player 1 button 2 is alt.  I just using this untill I get my frontend worked out.  Its take some getting use to but it works fine.
17 years old and totaly addicted.
kiddk1
  • HAP KI DO
« Reply #5 on: April 30, 2006, 05:47:51 pm »
I am experimenting with some frontends now, mamewah is cool but if I accidently hit the start button on my keyboard the screen goes out and I have to reboot, this probably wont be an issue once my CP is in place,  I couldnt get atomicFE to work I dont know how to config it?
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #6 on: April 30, 2006, 10:52:00 pm »
I run mame32 with gameex for the frontend & it works perfect
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
rockmes
  • Last login:June 05, 2016, 09:41:38 am
  • Don't you love it?
« Reply #7 on: May 01, 2006, 01:16:06 am »
l also run mame32 with mamewah and never had issues. l use mame32 , cos l noticed better picture quality and smoothness of the games like sfa3. Try it yourselves and see the difference .
loadman
    • MaLa
« Reply #8 on: May 01, 2006, 05:14:32 am »
No doubt you are not running it on an old PC
Mame 32 won't make any diffrence to graphics as its the same code with FE built in. You probably just didn't have all the settings the same in mame.ini.
No it is not hard.  A command line is (for eg   mame.exe invaders). This would launch invaders.  A FE sends the command line to mame for you. When you are ready there is plenty of docs out there on setting a FE up
Havok
  • Trade Count: (+17)
« Reply #9 on: May 01, 2006, 08:53:10 am »
Atomic is easy to configure. Just run AtomicManager.exe in the directory where you installed Atomic (most likely c:\AtomicFE_v015) and click on the Folders tab. Point everything in there to where your stuff is located and Save. Here are the main files:
- Atomic.exe: program that will launch AtomicFE once it
kiddk1
  • HAP KI DO
« Reply #10 on: May 01, 2006, 10:29:21 am »
I installed game ex yesterday and part of my experimenting with FE's and It is stuck on the screen that asks for a donation, i configured it(told it where my mame dir and roms are)  I am running mame 097.
Havok, thanks for the advice, I got it working, I will look into docs as to changing layout.
« Last Edit: May 01, 2006, 10:40:54 am by kiddk1 »
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
« Reply #11 on: May 01, 2006, 10:40:18 am »
The donation screen stays stagnant for about 3 to 4 minutes or so, make sure you are waiting long enough.
I had to beat them to death with their own shoes...
kiddk1
  • HAP KI DO
« Reply #12 on: May 01, 2006, 10:41:16 am »
I gave it about 15min
JonnyBoy
  • Inka Dinka Do
« Reply #13 on: May 01, 2006, 10:44:06 am »
Yeah, it probably froze, what specs are the PC you're running?
Havok
« Reply #14 on: May 01, 2006, 12:02:08 pm »
Wow! 3 - 4 minutes? When I was testing FE's to decide which one I was going to run, that screen stayed up for about 5 seconds for me. I am running an AMD 3300+, but still that seems overly long for even a slow pc...
JonnyBoy
  • Inka Dinka Do
« Reply #15 on: May 01, 2006, 12:09:15 pm »
Well, I do all my testing on a PIII 733, which is probably responsible for that large duration of time. I plan on donating so I can rid of the damn screen for good, though. The program, in my opinion, is well worth the donation cost.
kiddk1
  • HAP KI DO
« Reply #16 on: May 01, 2006, 08:08:48 pm »
okay after a reboot gameEX is working and I think I like it the best b/c of all the options I have.  Atomic is cool but limited compared to gameEX.  I just need to read up on gameEX to figure out how to do my own layouts and change certain options, it did not come with a readme file.  Thanks for all the help
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #17 on: May 02, 2006, 03:47:40 am »
GameEX is more a Media center  , AtomicFE is a only a Front End.   If you compare FrontEnd feature i don't think Atomic is limited in comparaison of GameEX , i think it would be the opposite. In Term of Media Center , yes, it is clear GameEX is better.  The 2 products don't have the same approach. If you take time to study in depth Atomic you will see that the front end as not really limits..    Atomic is currently limited by his configurations tools that don't allow to exploit the all the power of the FE easily.  But it will change very soon...
JonnyBoy
  • Inka Dinka Do
« Reply #18 on: May 02, 2006, 07:04:28 am »
I agree with Youki, AtomFE is a fine frontend. It does what's needed to run games. GameEx has all those little media features alongside the front end. They are two different animals.
« Reply #19 on: May 02, 2006, 07:42:05 am »
That's just a configuration issue...MAME32 is the same as MAME with a FE.  My guess is with MAME you just used the defaults...for example hardware stretching is switched on and triple buffering off by default...whereas the opposite are better for image quality.
kiddk1
  • HAP KI DO
« Reply #20 on: May 02, 2006, 01:27:54 pm »
in setting up the FE I notice there are snap paths, flyer, marquee, title... paths.  what exactly are these they were not mentioned in the docs I read  or at least I didnt see them?
youki
    • Atomic Front End
« Reply #21 on: May 03, 2006, 03:29:45 am »
Snap  are snapshot  , the snap path point to a folder that contains screen capture of games.
Title are snapshot too, but they are screen capture of the title of the game.
Marquee , Flyer  are picture too.
Some layout or skin in front end displays these information if you have it.   If you don't that should not be a problem, they won't be displayed that's all.
If you don't what are snap, marquee..etc... i suggest you make point all these folder to a same empty folder.
kiddk1
  • HAP KI DO
« Reply #22 on: May 03, 2006, 12:55:01 pm »
thank you.
danny_galaga
  • Last login:April 17, 2026, 10:06:35 pm
    • dans cocktail lounge
« Reply #23 on: May 07, 2006, 06:01:29 am »
i use mame32 only on my cab too. if you use an ipac keyboard emulator or the like then yuo CAN exit from games without a keyboard, i also used a macro to shut it down. im very impressed with atomic and my next project will definitely use it. it would be on my cab now but it is about 2500km away  :(
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« Reply #24 on: May 07, 2006, 08:56:58 pm »
I was using only mame 32 on my main pc and it works fine.  I'm currently building my first mame cab, and after looking around I think I'm going to be using game ex as my front end.  To me it just seems so smooth and has alot of nice features I can use.
kiddk1
  • HAP KI DO
« Reply #25 on: May 10, 2006, 02:57:08 pm »
divemaster, I tried this but am finding that gameex locks up with mame32, it goes to the screen where you select the game and starts to launch the game then locks up.
