Author Topic: Removing smoke odor  (Read 3255 times)
psychopanda
  • Last login:August 31, 2006, 01:13:17 pm
    • PsychoPanda's Secret Grotto
Removing smoke odor
« on: April 27, 2006, 06:27:42 pm »
I picked up a coin door and it (surprisingly) has a strong smoke odor. I've never really noticed that with metal parts before.
Does anyone have some suggestions on how to remove smoke odor from metal?
gonzobrian
  • Last login:April 18, 2011, 08:42:08 pm
  • This space for rent!
Re: Removing smoke odor
« Reply #1 on: April 27, 2006, 09:17:03 pm »
The Myth Busters say spray Vodka on it.  And if it does not work you always have the vodka.   I would rinse the vodka off after a bit.  Otherwise you would just trade one bar odor for another.
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #2 on: April 27, 2006, 10:37:33 pm »
usually just let it set in your garage for a while air will take care of a lot of it & spray it with a all purpose cleaner
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« Reply #3 on: April 28, 2006, 01:04:37 am »
Give it a nice new paint job  8)
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
psychopanda
« Reply #4 on: April 28, 2006, 10:42:23 am »
Thanks guys, it's been sitting in the garage for about a week but no real change. I sprinkled sawdust over the top of the coin box (something I have an abundant supply of in the garage!) just to see if it will neutralize the odor somewhat.
If I find something that works, I'll post it here so that others can benefit too.
thebrownshow
  • Last login:December 14, 2010, 03:14:32 pm
« Reply #5 on: April 28, 2006, 11:32:56 am »
You could always start smoking.  When I was a smoker, smoke odor never bothered me ;)
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #6 on: April 28, 2006, 01:09:18 pm »
Spray the inside with Lysol, that seems to work for me.  You will have to do this more than once to get rid of it.  Also re-painting the outside will have to be done.  Ive never tried to get rid of the smoke from the outside, always repainted.
Next I'll be on fries, and that's when the big money starts rolling in.
RickDIII
  • Last login:June 03, 2007, 10:18:28 pm
  • Finished 1st Cab!
« Reply #7 on: April 28, 2006, 01:12:14 pm »
Mythbusters rule!  :notworthy:
I saw that episode and the Vodka made a difference on clothing, not sure what it would do on a coin door.
Stingray
« Reply #8 on: April 28, 2006, 04:05:20 pm »
Simple Green works really well. Sadly, I learned this after a house fire.
-S
psychopanda
« Reply #9 on: April 28, 2006, 05:17:25 pm »
I smoked for 10 years, and yes, when you are a smoker you never notice the smell. I like to think I was relatively clean in my smoking habits because I never smoked inside my home, but I'm guessing this coin door once lived in a bar where smoking was alot more frequent.
I could stand it myself, but it pretty much smells like an ashtray and my never-smoked-a-day-in-her-life wife isn't going to be too crazy about it.
Tailgunner
« Reply #10 on: April 30, 2006, 01:41:17 am »
The smell is caused by a film of cigarette smoke stuck on the coin door's surface. Simple Green works good,  Greased Lightning works better. Wash it over a white sink, you'll be amazed what runs off.
I smoke, and every so often I tear my computer down and give it a bath to remove that film. :)
SithMaster
« Reply #11 on: April 30, 2006, 11:39:10 am »
smoking is bad for me. :blah:
j123vt_99
  • Last login:August 24, 2006, 09:41:12 am
« Reply #12 on: May 01, 2006, 06:25:56 pm »
won't washing it cause it to rust?
Pictures of my Missile Command  http://www.nimsu.com/mc/mc.html
psychopanda
« Reply #13 on: May 02, 2006, 01:02:40 pm »
Probably not, most of the door is painted pretty solid.
Well, so far I tried spraying a little Greased Lightning and wiping it off. I might try that again, but no luck so far.
Recently we sealed it in a plastic bag with a bowl of baking soda. But I opened the bag to remove the key locks yesterday and the smell doesn't seem to have changed any.
Still to try; Lysol and Simple Green. Painting probably isn't an option, since I don't want to mess up the paint (trust me, I mess up everything!).
thebrownshow
« Reply #14 on: May 02, 2006, 01:24:48 pm »
http://retroblast.com/articles/coindoorrestore.html
psychopanda
« Reply #15 on: May 17, 2006, 02:56:16 pm »
Ok, so a couple of weeks sitting in a plastic bag with baking soda sure didn't work.
I finally got back to this and I decided to take apart the door and wash it down in case I need to repaint the whole thing. One of the black plastic frames outside the coin plunger broke, but I think its "super gluable". Just a note, be careful when removing them.
Well, I washed it all down and scrubbed with a cell-o pad using some dishwashing soap (scented with apple?) and wouldn't you know it?! Most of the smoke smell went away! As I was washing it, a yellowish film came off. I've scrubbed it and let it dry twice now and other than the plastic pieces, the odor is barely noticeable now. Which is nice. I might add one coat of black spray paint over the top just to make the door look a little newer and eliminate any odor remnants.
Anyways, that was my solution in case anyone else runs into the same issue.
thebrownshow
« Reply #16 on: May 17, 2006, 03:22:31 pm »
Thanks for posting your solution.  It's always great to see people do that.
psychopanda
« Reply #17 on: May 17, 2006, 07:14:02 pm »
Yeah, not sure how many times I've stumbled upon a thread which posed several questions/solutions but then the person drops off the face of the Earth and I wonder...so what worked?!
My solution is pretty simple, but maybe others will try it before buying more expensive things?
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #18 on: May 19, 2006, 08:46:03 pm »
Lemon Juice is the bomb.
John
Galaga... Was there any other game?
jhanson
« Reply #19 on: May 20, 2006, 07:25:17 am »
As I found out when I bought my current house a few years back, diluted trisodium phosphate works great for removing smoke smell.  Wipe it on with a sponge, and watch the yellow tar drip off.  However, I probably wouldn't try it on a coin door, as I think it makes metal rust.  However, if you've got a wooden surface, like say an arcade cabinet, it would work wonders.
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« Reply #20 on: May 21, 2006, 11:18:41 pm »
I bought some stuff over Ebay that came from a smoker - the stuff reaked. Believe it or not, Febreeze actually cleared it right up.
Make your cabinet look its best with custom art from
Gamecreature!
Cameronj
  • Last login:August 03, 2012, 12:59:01 pm
  • I'm a Super llama!
« Reply #21 on: May 22, 2006, 11:06:58 pm »
I have a Pacman that was totally smoky. I left it in the garage, but it only made the garage stink. I sprayed it liberally with Febreeze and left it over night. The next morning, the garage didn't smell anymore. I repeated this process for 3 nights (wiping off the residue from the night before) This worked awesome. I moved the unit into the house. After about 2 years I started to smell a little smoke again so I sprayed it once with febreeze and it has been good for a long time after. Hope this helps.
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
« Reply #22 on: May 24, 2006, 06:57:18 pm »
I bought a used ps2 of a smoker on eBay and man the controler stunk. And every time I touched that controler my hands would stink. But I want my cooindoor to stink. I believe that it would give my rec room that authentic bar feel ( I mean smell).
As we speak i am sticking my coin door in a plastic bag full of cigars
They treated me like an animal and that's what I became.
