Author Topic: Some beginners advice on wiring needed  (Read 3224 times)
getoffmyland
  • Last login:May 09, 2006, 02:34:02 pm
« on: April 19, 2006, 09:41:27 am »
Hi everyone,
I am trying to link 4 arcade buttons with cherry microswitches to an IPAC2 bought from Ultimarc.
What type of wire is best recommended for this? And would i be able to get it from a DIY/Electricians shop?
Thanks.
Matt.  :)
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
Re: Some beginners advice on wiring needed
« Reply #1 on: April 19, 2006, 10:07:18 am »
18 or 20 guage stranded work just fine.  You could even get away with a CAT5 cable if you wanted to help keep the wires neat.
Radio Shack has this stuff or yes, any electronics shop will have it.
Tek
« Last Edit: April 19, 2006, 10:09:08 am by Teknique »
Your screen name has been added to my frag list.
dpz147
  • Last login:March 18, 2020, 11:49:34 am
« Reply #2 on: April 19, 2006, 10:46:17 am »
I'm fairly new at this but I used 20 gauge solid core i picked up at Radio Shack and it worked great for me.  From what I've read, the solid core is better for bending purposes.  Outside of that, I'm not sure if there are any pros/cons for solid vs. stranded.
hnugz
  • Last login:September 14, 2013, 06:18:38 pm
    • Horrorcore Games
« Reply #3 on: April 19, 2006, 11:07:11 am »
from what i understand solid will tend to break easier due to bending.  stranded seems to be easier to work with.
"Don't play pinball if you only got one arm, cuz your score will suck."
lordtodd75
  • Last login:July 21, 2020, 01:42:37 am
  • I especially hate punks!
« Reply #4 on: April 19, 2006, 12:48:20 pm »
Solid core will break easier then stranded, so If you are going to be moving the wiring around, use stranded. I would use a cat5 cable with some quick connects. Nice and neat.
getoffmyland
« Reply #5 on: April 19, 2006, 01:25:32 pm »
Excellent, thanks for all your quick responses.
Also, this will make you laugh but i need to make sure.. how do i connect the wires to the buttons?
I already know about 'normally open' and 'closed' bits.. Do i solder the wires on or can i just wrap the ends around the metal bits on the button?
Thanks,
Matt
AtomSmasher
    • Atomic-Train
« Reply #6 on: April 19, 2006, 01:30:13 pm »
Use crimp on connectors like these:  http://www.radioshack.com/product/index.jsp?productId=2103313&cp=&origkw=Female+Crimp-On&kw=female+crimp-on&parentPage=search
you can find them in any hardware store.
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
« Reply #7 on: April 19, 2006, 01:46:13 pm »
I warn you now dont let your brother solder anything for you, Because of him I have balls of solder the size of a basketball.
17 years old and totaly addicted.
AtomSmasher
    • Atomic-Train
« Reply #8 on: April 19, 2006, 01:57:37 pm »
I'd recommend reading issue #4 of retro revival because they have an artical on installing an IPac.  You can download the issue here: http://www.retrorevival.co.uk/site/index.php?option=com_docman&task=cat_view&gid=17&Itemid=26
Buddabing
« Reply #9 on: April 19, 2006, 02:38:32 pm »
18 gauge wire is pretty thick for this purpose. Use "hookup" wire, which IIRC is 22 gauge. Or stranded cat 5 cable.
To connect buttons to wire, use quick disconnects from Peale.
Please read the wiki!
clhug
  • Last login:April 04, 2024, 10:49:58 pm
« Reply #10 on: April 19, 2006, 02:43:46 pm »
I've been looking for these myself.  Looks like all my connections use 3/16" but all I can find at any of the hardware stores are 1/4".  The link posted for Radio Shack contains 3/16" but it's a mix of 3/16" and 1/4" so it's kind of a waste of money.  So far I've been unable to find anybody (at least a local store) that sells packages of only 3/16".
AtomSmasher
    • Atomic-Train
« Reply #11 on: April 19, 2006, 02:49:10 pm »
I used 1/4'' for all of mine and they worked fine.  Actually I got them from Ultimarc, I ordered their "wiring kit" for the IPac and it came with 1/4'' connects.
getoffmyland
« Reply #12 on: April 19, 2006, 07:44:57 pm »
Thanks for the advice,
I was looking at the wiring kit from Ultimarc but i need it for such a short time
yhw4life
  • Last login:July 15, 2008, 06:43:19 pm
« Reply #13 on: April 20, 2006, 02:41:59 am »
I just recently got into this hobby, and hopefully will be building my own soon.  The main part I was confused on, was the wiring of the controls.  That retro revival article REALLY helped.  Thanks a lot.
clhug
« Reply #14 on: April 23, 2006, 12:02:11 pm »
Okay, that was a big "DUH" moment for me.  I never even thought about the fact that you could use the larger female connectors on the smaller male spade.  I went ahead and got some 1/4" females.  The only thing I see there is that they were very loose so I used a pair of pliers to squeeze down the curled over edges a bit to make it so they wouldn't pull off quite so easily.  Don't squeeze the too much though or you won't be able to slide them on either. :)
iamnaeth
  • Last login:August 08, 2018, 02:42:59 pm
« Reply #15 on: April 23, 2006, 12:51:25 pm »
Just and FYI, you can get the connectors at most hardware store too.  I picked up my connectors at True Value.  They had more selection than my local radio shack  ::)  pathetic.
clhug
« Reply #16 on: April 23, 2006, 01:07:33 pm »
Yes, probably cheaper too.  I got mine at Lowe's.  Home Depot and Menard's also carry them.  You can buy big bulk packs at these places for good prices.  Don't remember exact price off the top of my head though.
danny_galaga
  • Last login:April 17, 2026, 10:06:35 pm
    • dans cocktail lounge
« Reply #17 on: April 24, 2006, 10:06:37 am »
automotive stores should have these too...
MYX
    • MYX Digital Blog
« Reply #18 on: April 24, 2006, 02:30:40 pm »
Frys Is one of the best places for most of this stuff if you have one near by. They also sell just about every color imaginable of heatshrink tubing in a brazillion sizes.
M    Y    X
