Author Topic: non t molding molding  (Read 3268 times)
juggle50
  • Last login:April 18, 2026, 05:13:26 pm
  • Your either on the bus or off the bus
« on: April 13, 2006, 09:15:40 pm »
Do you guys know of any molding that doesn't have th "t" in it and is maybe backed with some adhesive?  I should have routed around my panel and it's too late now.  It's for a desktop controller and it would only be about 4 and half feet that I would need.
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
Re: non t molding molding
« Reply #1 on: April 13, 2006, 09:20:48 pm »
I don't think anything with adhesive is going to hold up very well.
You could glue strips of Formica to the edge and then use a flush trim bit on it.  Also they make an edging material that you iron on that might hold up better.
Dizzle
  • Last login:August 09, 2014, 05:28:04 pm
« Reply #2 on: April 13, 2006, 09:24:24 pm »
I wound up buying t molding and cutting the spine off with an exacto knife.  Then I used a hot glue gun to install it.  Not the preferable way to do it, but it worked pretty well for me.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #3 on: April 13, 2006, 10:45:53 pm »
Step one:  Choose the color of T-molding you want.
Step two:  Go buy some paint in that color.
Step three:  Paint the edges.
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #4 on: April 13, 2006, 11:33:27 pm »
that would look awfull... just leat it bare... or possibly get some L shaped corner molding
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« Reply #5 on: April 14, 2006, 02:15:34 am »
Be hard to to do with chrome molding
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
PoDunkMoFo
    • Visual Horizons
« Reply #6 on: April 14, 2006, 03:06:04 pm »
That might work if you bondo'd the edge and did a good job prepping it but if you just painted the bare edge it would look pretty crappy.
Dustin Mustangs
  • Last login:September 14, 2017, 11:43:18 am
  • Cut the sheet!
    • My Site
« Reply #7 on: April 14, 2006, 03:36:06 pm »
There is a 3mm and 5mm glue on edge banding that many cabinet (non-arcade) manufacturers use to finish edges.  It's flat, not rounded like t-molding so it won't look much if anything like it but it will provide you with a finished edge of a chosen color.  You can likely find some around your house to see what it looks like.  Look for a cabinet (again, non-arcade) that isn't made out of solid wood.  It's edges will be finished in the 3mm variety and you might find the 5mm on the edges of the doors.
Expensive machines are the normal way of applying this stuff, but some times due to the shape of the board the only option is to glue it on by hand using a high-strength contact adhesive.  This does hold up pretty well and look nice when done right.  I'm not sure where or if this stuff is commercially available, but it might be something to look into.
mj147
  • Last login:November 10, 2024, 08:04:14 pm
« Reply #8 on: April 14, 2006, 03:46:21 pm »
A good and easy solution would be that iron on edging found in places like Home Depot. Ive used this stuff with great results.
Some eBay examples;
http://search.eBay.com/iron-on-edging_W0QQfnuZ1QQfsooZ1QQfsopZ3QQxpufuZx
mj147
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
« Reply #9 on: April 14, 2006, 07:10:57 pm »
If I bought t-molding and cut off the middle insert portion, what glue should I use to attach it.
juggle50
« Reply #10 on: April 16, 2006, 03:47:08 am »
Thanks for the suggestions guys, I think I'm going to try to cut off the edging of t molding and use a hot glue gun.  If that doesn't work I may try some of that iron on.
MikeDeuce
  • Last login:September 15, 2013, 04:38:38 pm
  • It does a body good.
« Reply #11 on: April 16, 2006, 11:24:46 pm »
Some more examples of the iron on stuff, saw a nice selection while thumbing through a rockler catalog on the toilet:
http://www.rockler.com/product.cfm?page=1294
