Author Topic: sound when i push a button  (Read 4071 times)
gabypotter
  • Last login:December 28, 2024, 12:36:33 am
  • I want to finish my Jukebox!!!
« on: March 25, 2006, 06:11:59 pm »
Hi, Chris!
i want to know if it is posibble to program
wincab to make a sound like credit sound,
when im press the numbers, is this posiblle?
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: sound when i push a button
« Reply #1 on: March 29, 2006, 11:55:32 pm »
You need to edit the skin file with a text editor and add the sounds you want.
Skins can contain pointers to sounds that are triggered when a button is pressed or an event occurs.  Sounds can be set to trigger either when a message or button is set or unset. To specify that a sound should be played when a message or button is unset, prefix the message or button name with a minus sign.  There is a special button derfinition called BTN_ANY that will respond to any button event.
Here is a sample sound definition set:
[Sounds]
BTN_COIN1=coin.wav
BTN_COIN2=coin.wav
BTN_ANY=btnclick.wav
MSG_START=startup.wav
-MSG_START=shutdown.wav
--Chris
gabypotter
« Reply #2 on: March 30, 2006, 03:20:15 pm »
wow!
thank you
i will try it right now!
