Author Topic: How can I gurantee no Mame games are rotated when starting?  (Read 3696 times)
unclet
« on: March 10, 2006, 08:49:34 pm »
When I start games in Mame via MameWah, some of the games are rotated 90 degrees.    How can I gurantee that all games start up/down rather than turned 90 degrees.
Here are some options I found in the Mame text, but there is no description as to which one does what ....
-[no]norotate
-[no]ror
-[no]rol
-[no]autoror
-[no]autorol
-[no]flipx
-[no]flipy
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: How can I gurantee no Mame games are rotated when starting?
« Reply #1 on: March 10, 2006, 11:53:13 pm »
Here is what that section of my mame.ini says:
### Mame CORE video options ###
norotate                0
ror                     0
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
debug_resolution        auto
gamma                   1.000000
brightness              1.000000
pause_brightness        0.650000
unclet
« Reply #2 on: March 11, 2006, 06:33:41 am »
How about starting of the game "005" and telling me if it is sideways for you ...
I set the "norotate = 1" and a "disclaimer" appears "non-sideways" now ..... which is good ..... however the actual game display is still sideways....
« Last Edit: March 11, 2006, 07:42:37 am by unclet »
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: March 11, 2006, 08:34:53 am »
What are your setting for
ror
rol
autorol
autoror
flipx
flipy
(All should be zero).
Also - All should be zero in both your mame.ini and gamename.ini (005.ini) files.
unclet
« Reply #4 on: March 11, 2006, 08:51:58 am »
When all those values were zero in my "mame.ini" then the disclaimer text (and also the mame configuration menu text ... when I hit TAB in the game) were tilted sideways and the 005 game was tilted sideways as well.
When I added "-norotate 1" then the disclaimer and menu text were straight up/down .... which is nice, but the 005 was then tilted sideways in the other direction.
Just to make myself clear ......  most games are perfectly fine ..... meaning they display striaght up/down like I want them, but I noticed some games (ie: 005 is one of them) which start off sideways.   I have not checked many other games yet, so I am not sure if there are more .... but I would expect there to be some more.
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: March 11, 2006, 09:04:50 am »
What type of monitor? (I.e. is it an arcade monitor and maybe you have the inputs swapped, or a rotated monitor, and you have should be using rol=1 to rotate the games to vertical?)  Wouldn't make some work and others not, though . . .
What version of MAME?  Are horizontal games fine and vertical games rotated, or are most horizontal and vertical games fine, and 005 and some others are messed up?
unclet
« Reply #6 on: March 11, 2006, 09:18:10 am »
I am currently setting up MameWah1.62b9, so I am strictly on my computer trying to set everything up.  I have a Samsung flatscreen.  I am using command line Mamev103
The 005 game is just one I noticed was sideways since it was listed near the top of the list.
Maybe you can provide me with a list of some horizontal games and some vertical games to check and I will look to see if the horizontal ones are sideways.
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: March 11, 2006, 11:00:49 am »
Vertical -
PacMan
Galaga
Galaxian
Top Gunner
Arkanoid
Horizontal -
OutRun
88 Games
Return of the Jedi
88 games
1944
etc.
« Reply #8 on: March 11, 2006, 12:04:29 pm »
I'll bet it's an intel chipset.
I had to install a new video card. Doesn't seem to be able to be resolved through software switches.
« Reply #9 on: March 11, 2006, 12:04:50 pm »
P.S. I love your jukebox software!
unclet
« Reply #10 on: March 11, 2006, 05:29:05 pm »
Vertical -
PacMan = sideways (not displaying how I want it)
Galaga = sideways (not displaying how I want it)
Galaxian = sideways (not displaying how I want it)
Top Gunner = displays up/down normal
Arkanoid = sideways (not displaying how I want it)
Horizontal -
OutRun = displays up/down normal
88 Games = displays up/down normal
Return of the Jedi = displays up/down normal
1944 = displays up/down normal
How can I rotate the games which do not display properly for me ..... ?
leapinlew:
nice to hear someone is actually appreciating my JUkebox software.  I made it to my specifications and I believe it to be quite solid.....
thanks for the nice words ....
« Last Edit: March 11, 2006, 05:39:50 pm by unclet »
Tiger-Heli
    • Tiger-Heli
« Reply #11 on: March 11, 2006, 05:54:01 pm »
Okay, there's some progress.
Except for Top Gunner, it looks like you are having a problem with all vertical games.
Does this mean that PacMan appears normal when you launch it from the commandline?
If not, then you need to look at autorol or autoror options in your C:\mame\mame.ini file (and set them to 0).
If it only happens in MAMEwah, you need to look at your MAMEwah mame.ini file settings, but I don't use it enough to advise you.
jcrouse
    • CPViewer
« Reply #12 on: March 11, 2006, 05:59:50 pm »
MameWAH will have no effect on how the game is displayed UNLESS you are specifically supplying some sort of video manipulation via the commandline. I am sure this is not the case and it would be across-the-board, for all games, unless you specify it on a per game basis which I am sure you are not.
John
unclet
« Reply #13 on: March 11, 2006, 07:07:05 pm »
I am not using MameWah for these tests .... I am executing the game via the command prompt (ie: mame galaga) and it still results in the game being sideways.
My INI file is listed below.   I believe everything you indicate I should have set to "0" is already set to "0".
NOTE: I am using multiple ROM paths .... but I can not see why this would matter...
### mame.ini ###
### Frontend Related ###
### Windows path and directory options ###
rompath                 C:\Emulators\RomFiles\Mame\romsA-D;C:\Emulators\RomFiles\Mame\romsE-L;
samplepath              samples
# inipath               <NULL> (not set)
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snaps
diff_directory          diff
ctrlr_directory         ctrlr
cheat_file              cheat.dat
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
direct3d                0
hwstretch               1
# screen                <NULL> (not set)
cleanstretch            auto
resolution              auto
refresh                 0
scanlines               0
switchres               1
switchbpp               1
maximize                1
keepaspect              1
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_brightness   0.000000
frames_to_run           0
effect                  none
screen_aspect           4:3
### Windows Direct3D 2D video options ###
zoom                    2
d3dtexmanage            1
d3dfilter               1
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               none
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
### Windows misc options ###
sleep                   1
rdtsc                   0
high_priority           0
### Windows sound options ###
audio_latency           1
# wavwrite              <NULL> (not set)
### Input device options ###
mouse                   1
joystick                0
lightgun                1
dual_lightgun           0
offscreen_reload        1
steadykey               0
keyboard_leds           1
led_mode                ps/2
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
paddle_device           keyboard
adstick_device          keyboard
pedal_device            keyboard
dial_device             keyboard
trackball_device        keyboard
lightgun_device         lightgun
digital                 none
norotate                0
ror                     0
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
gamma                   1.000000
brightness              1.000000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                 0.000000
intensity               1.500000
### Mame CORE sound options ###
samplerate              44100
samples                 1
sound                   1
volume                  0
### Mame CORE misc options ###
artwork                 0
use_backdrops           0
use_overlays            0
use_bezels              0
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# debugscript           <NULL> (not set)
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
oslog                   0
skip_gameinfo           1
bios                    default
# state                 <NULL> (not set)
autosave                0
### Configuration options ###
readconfig              1
verbose                 0
« Last Edit: March 12, 2006, 07:25:00 pm by unclet »
« Reply #14 on: March 11, 2006, 11:57:34 pm »
Uncle T
Are you using an onboard intel Video card?
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
« Reply #15 on: March 12, 2006, 09:53:11 am »
Here's my suggestion, for what it's worth
- Right click on your empty desktop and select 'properties'
- Select the 'settings tab'
- Press the 'advanced' button
- I'm guessing you'll have a tab that says 'intel' something.  Click it.
- Click 'graphical properties'
- Click 'display settings'
- Uncheck 'enable rotation'
- Click 'hot keys'
- Uncheck 'enable hot keys'
This was my problem when this happened to me.
unclet
« Reply #16 on: March 12, 2006, 07:23:39 pm »
MY PROBLEM IS SOLVED !!!!
Yes I had an onboard Intel chip .... thanks for telling me the exact steps to fix the problem ....
I guess the problem is that the Intel chips have those settings default to "ON" rather than "OFF" ?
« Last Edit: March 12, 2006, 07:31:52 pm by unclet »
« Reply #17 on: March 13, 2006, 12:07:55 am »
Awesome... this needs to be in a FAQ or more readily available. I ended up getting a different vid card. But, in this hobby, whats another 80 bucks?
