Author Topic: Cocktail Fan question  (Read 3152 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: March 08, 2006, 06:02:42 pm »
Hi all, another fan question.  I have searched and found some good info and sites to buy my fans from.  I have a question though.  I am building a 27
« Last Edit: March 08, 2006, 06:04:23 pm by squirrellydw »
I b**ch. People listen!!
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
Re: Cocktail Fan question
« Reply #1 on: March 08, 2006, 06:40:36 pm »
OH..Uh... Wait. Are you or are you not a fan of cocktails? (I prefer the vodka martini  ;D
I'm also building a cocktail table based on a design similar to the Whammocade. I was planning on using the same amount of fans as the Whammocade even if it is overkill because I have a car amp and two PC power supplies. So I am going to have a little more heat to get rid of.
Regarding your fan choice, I think that the price might be a little steep. Check eBay.
I have seen similar fans for $3.99.
They treated me like an animal and that's what I became.
squirrellydw
« Reply #2 on: March 08, 2006, 07:41:40 pm »
I know the fans might be high, but I have read that these are very good fans.  Have you seen the same ones or "similar" ones??  Anyone else??
jcrouse
    • CPViewer
« Reply #3 on: March 08, 2006, 07:45:37 pm »
Multiple fans can get pretty noisy. I would spend a little extra and get silent or quiet fans. I ususlly get mine from www.newegg.com.
John
squirrellydw
« Reply #4 on: March 08, 2006, 09:03:31 pm »
John
What ones would you recommend?
jcrouse
    • CPViewer
« Reply #5 on: March 08, 2006, 09:28:44 pm »
Personally I think seven is WAY overkill. I run two of these in my cocktail and have never gotten close to having any heat issues.
http://www.newegg.com/Product/Product.asp?Item=N82E16811999603
John
whammoed
  • Last login:April 17, 2026, 12:27:07 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #6 on: March 08, 2006, 09:36:24 pm »
John
I must speak up on this comment.  Are you using a 27" d9200 monitor in your cocktail?  Or for that matter any of the 27" multisynch monitors that seem to fail when you sneeze wrong?  That many fans may indeed be overkill but when dealing with this setup I think it may be better safe than sorry since there are those that say overheating for this monitor can be an issue.  I would run at least two taking air in on the bottom and two blowing out near the top plus one fan blowing on the neckboard if you are running a d9200.
jcrouse
    • CPViewer
« Reply #7 on: March 08, 2006, 09:41:10 pm »
It's good that you did. I meant to say that I am using a 19" WG monitor in my cocktail. As far as blowing in, personally I do not believe that is necessary, however the fan on the neck of the monitor (blowing towards exaust fans in the rear) is probably a very good idea. I would personally listen to Whammoed since he has much more experience than myself. I would, however, go with some sort of silent fans.
John
Havok
  • Trade Count: (+17)
« Reply #8 on: March 09, 2006, 09:14:26 am »
squirrellydw
« Reply #9 on: March 09, 2006, 09:57:11 am »
Code: [Select]
I highly recommend Thermaltake fans - I have some, and am very satisfied. I replaced all my fans in my pc last year, and not only does it run cooler, it is now silent.
For an extra dollar, you might want to check this one out:
http://www.casecooler.com/thsicat8cm.html
so if I go with 7 of those and 1 120mm I should be ok.  I just want to make sure I have enough cooling and I would like it to be some what quite.
How do you mount them if you want them to blow in the other direction, looks like they only mount on one side??
Or I could use 7 of these  http://www.casecooler.com/80vanstealfa.html
« Last Edit: March 09, 2006, 10:03:05 am by squirrellydw »
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #10 on: March 09, 2006, 11:04:38 am »
Happ sells some arcade fans(4.69" square x 1.5" deep) , these are die cast metal & they are a little high but i used 2 of them blowing out the top of my cab since heats rises...
below are the specs i could not imagine 8 fans that would sound like a dc3 taking off
thanks
dm
Top quality fan cools the electronics in your video game
Industry standard size 4.69" square x 1.5" deep
Low noise; impedance protected
110/120V AC fan easily mounts in most equipment
UL Approved
Sealed ball bearing type
Air flow 98-106 CFM ( Cubic feet per minute)
Cast aluminum frame
2,900 - 3,200 RPM
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Havok
« Reply #11 on: March 09, 2006, 11:40:10 am »
Code: [Select]
Yeah - those will only mount in one direction. Those Vantecs would probably work better for you, and at 21db, will be nice and quiet.
thanks
dm
UL Approved
Cast aluminum frame
2,900 - 3,200 RPM
Those sound good, if you have the room for them - since this is a cocktail. Awesome airflow, but I wonder what the actual db noise rating is?
squirrellydw
« Reply #12 on: March 09, 2006, 05:18:11 pm »
yeah, I like the airflow also, but what is the noise??  32 is the highest  I wanna go.  right now I am going with the Vantecs unless someone else has something else.
thanks guys, I am going to get 7 of these and 1 120mm vantec since the pano is out of stock
« Last Edit: March 10, 2006, 11:20:09 am by squirrellydw »
